Balancing Equations: Nitrogen Dioxide + Water = Nitric Acid
The discussion focuses on the chemical equation for the reaction between nitrogen dioxide and water to form nitric acid. Initially, the equation "NO_2 + H_2O = HNO_3" is presented, but it is identified as unbalanced due to hydrogen discrepancies. The correct reaction involves an additional oxygen molecule, leading to the balanced equation "4NO_2 + 2H_2O + O_2 = 4HNO_3". The user shares a method for balancing equations, emphasizing the order of balancing complex ions, low-numbered atoms, and high-numbered atoms.
  • Chemical equation balancing techniques
  • Understanding of stoichiometry
  • Familiarity with chemical reaction types
  • Basic knowledge of nitrogen compounds
  • Study advanced stoichiometry methods for complex reactions
  • Learn about nitrogen oxides and their reactions
  • Explore algorithms for automating chemical equation balancing
  • Investigate the role of oxygen in oxidation-reduction reactions
Chemistry students, educators, and anyone interested in mastering chemical equation balancing and understanding nitrogen compound reactions.
recon
Hi,
I've always had trouble balancing equations. Does anyone know if there is an 'algorithm' for balancing equations? For example, how do I balance
"Nitrogen Dioxide + Water = Nitric Acid"-Sorry, don't know how to use Latex!
Any help will be greatly welcomed.
Chemistry news on Phys.org
What I always do is balance things in this order:
1. complex ions
2. atoms with relatively low numbers
3. atoms with high numbers
Here is what you wanted balanced (I think)
[tex]NO_2 + H_2O \rightarrow HNO_3[/tex]
This equation by itself cannot be balanced. The nitrogens balance, the oxygens balance, but the hydrogens do not balance. Trying to balance the hydrogens makes the problem bigger.
The reason it cannot be done is because that equation is not correct. The real reaction that happens is:
nitrogen dioxide + water + oxygen = nitric acid
[tex]NO_2 + H_2O + O_2 \rightarrow HNO_3[/tex] (unbalanced)
Here is balanced:
[tex]4NO_2 + 2H_2O + O_2 \rightarrow 4HNO_3[/tex]
This is a strange reaction that my method doesn't work too well on. I started by balancing hydrogens, then nitrogens, then oxygen.
