Trig problems (Interference/diffraction and slits))
  • Thread starter Thread starter AznBoi
    Trig
The discussion revolves around interference and diffraction problems involving slits, focusing on the geometric and trigonometric relationships necessary to derive key equations such as d sin θ = m λ and y = (m λ L) / d. Participants express challenges in connecting angles and understanding the approximations used for small angles.
  • Participants discuss the relationship between sin θ and tan θ for small angles, with one participant seeking clarification on why these two functions are approximately equal. Others explore how to develop an intuitive understanding of these relationships without relying on geometric drawings.
Some participants have gained clarity on the approximations used in trigonometric functions for small angles. There is ongoing exploration of the application of the derived equations to both single and double slit diffraction, with distinctions made between the parameters involved in each case.
Participants are navigating the complexities of trigonometric relationships in the context of diffraction and interference, with specific attention to the implications of small angle approximations. There is a mention of standard approximations like sin x ≈ x for small x, which are relevant to the discussion.
AznBoi
Interference and diffraction problems involving slits includes a lot of geometry and trig right? I'm having a hard time deriving the equtions: [tex]d sin \theta=m \lambda[/tex] and [tex]y=\frac{m\lambda L}{d}[/tex] because there are some many geometry stuff you need to do to connect the angles.
Can someone explain to me why [tex]tan\theta=sin\theta[/tex] if theta is small? thanks
Can someone explain to me why [itex]sin \theta = tan \theta[/itex] if theta is small? thanks
Look at a right triangle. Now consider the definition of Sin and Tan.
[tex]Sin \theta = \frac o h[/tex]
[tex]Tan \theta = \frac o a[/tex]
if [itex]\theta[/itex] is small the adjacent side is very nearly the same length as the hypotenuse. So Sin and Tan are very nearly equal. Another way to see this is to look at the Taylor series expansion of Tan and Sin both have the same first term [itex]\theta[/itex] when you drop all but the linear term, you have [itex]sin \theta = tan \theta = \theta[/itex]
Okay I get it now, thanks. How does one develop the ability to see these kinds of connections without drawing triangles etc.? Is it just practice with these type of trig problems?
Anyways, is this equation used to determine the distance bewteen bright/dark fringes in single slit diffractions of light? [tex]y=\frac{m\lambda L}{d}[/tex] Except that (d) is replaced with (w), the width of the slit right? This equation applies to both double slit and single slit? So the only difference is that (d) is the distance between the slits in the two slit diffractions while (d) is the width of the slit in single slit diffractions? Thanks.
sinx=x for small x is a pretty standard approximation that crops up time and again... and of course, tanx = sinx/cosx, and cosx is about 1 for small x
