How Does Coulomb's Law Apply to These Electric Field Problems?
  • Thread starter Thread starter moonlit
    Fields
The discussion revolves around applying Coulomb's Law to various electric field problems involving point charges and conducting spheres. Participants are exploring the relationships between charge, distance, and force in electrostatic scenarios.
  • Mixed
  • Participants discuss the application of Coulomb's Law to determine forces between charges, questioning the appropriate equations and setups for different scenarios.
Some participants have provided equations and methods for calculating forces, while others express confusion about specific aspects, such as the interpretation of distance in the context of conducting spheres. There is an ongoing exploration of how charges interact when brought into contact and then separated.
Participants are navigating the constraints of the problems, including the need for clarity on the definitions of distance and charge interactions without needing to know the physical dimensions of the spheres involved.
moonlit
I have 3 problems I'm stuck on for homework:
1) The force of repulsion that two like charges exert on each other is 4.3 N. What will the force be if the distance between the charges is increased to 9 times its original value?
Not sure what equation to use here to solve this one...
2) Two tiny conducting spheres are identical and carry charges of -20.1 C and +38.8 C. They are separated by a distance of 1.96 cm. (a) What is the magnitude of the force that each sphere experiences? (b) The spheres are brought into contact and then separated to a distance of 1.96 cm. Determine the magnitude of the force that each sphere now experiences.
What equation should I use here? The one I'm using below?
3) A charge of -3.06 C is fixed at the center of a compass. Two additional charges are fixed on the circle of the compass (radius = 0.134 m). The charges on the circle are -3.02 C at the position due north and +6.29 C at the position due east. What is (a) the magnitude and (b) direction of the net electrostatic force acting on the charge at the center? Specify the direction as an angle relative to due east.
For part A I used the equation Fe=Kq1q2/r^2
Fe=-3.06*10^9*(-3.02*10^-6)*(6.29*10^-6)=.058127148/(.134)^2=3.237199153
I know this is wrong, can anyone help me find my problem?
1) You know that the force between two charges is:
[tex]F_{ele} = K\frac{q_1q_2}{r^2}[/tex]
So to compare the force between and after the change, divide them:
[tex]\frac{F_{ele1}}{F_{ele2}} = \frac{K\frac{q_1q_2}{r_1^2}}{K\frac{q_1q_2}{r_2^2}} = \frac{r_2^2}{r_1^2}[/tex]
And if [itex]r_2 = 9r_1[/itex] then:
[tex]\frac{F_{ele1}}{F_{ele2}} = \frac{9^2r_1^2}{r_1^2} = 9^2 = 81[/tex]
So the answer is that the magnitude of the force will be 1/81 of its original value.
2) You can answer the first part of the question with the equation above for [itex]F_{ele}[/itex]. After they bring the spheres into contact, the charges on them move between the spheres so the after they are separated, the charge on each one is different than the charge specified in the beginning of the question. When the spheres touch each other the charges on each one equalizes, so if at first they had (-20.1c + 38.8c) = +18.7c, after they are separated they will each have half of that i.e +9.35c.
3) Calculate the force that the charges on the circle exert on the charge in the middle, one at a time. You will get the magnitude of the force that operates along the north-south line, and the magnitude of the force that operates along the east-west line. When you have those use pythagoras to find the net force. To find the angle, use any of the trigonometric functions on the right triangle that consists of the two individual forces and the net force.
I understand problems one and three but the second problem I still don't understand. How do I know the radius of the sphere?
You don't need to know that, the formula only requires the distance between the spheres which you have.
Just in case you are confused, r there is NOT the radius of the spheres. It is the distance between them.
10K
