How to Prove Properties of Legendre Polynomials?
The discussion revolves around proving properties of Legendre polynomials, specifically the relationships P_n(-x)=(-1)^n*P_n(x) and P'_n(-x)=(-1)^(n+1)*P'_n(x). The subject area is polynomial functions within the context of mathematical physics.
  • Participants discuss using the series expression for Legendre polynomials and the implications of substituting -x into the series. There are inquiries about how this substitution affects the differentiation of the polynomials. Some participants suggest leveraging the even and odd properties of the polynomials based on their degree.
The discussion includes various attempts to understand the derivation of the properties from Rodrigues' formula and the implications of variable substitution. Some participants express uncertainty about the effects of differentiation when substituting -x, while others indicate they have made progress in understanding the properties based on the degree of the polynomials.
Participants reference external resources for definitions and properties but note that these sources do not provide derivations. There is an ongoing exploration of assumptions related to the nature of Legendre polynomials and their behavior under transformation.
neelakash
I am to prove that P_n(-x)=(-1)^n*P_n(x)
And, P'_n(-x)=(-1)^(n+1)*P'_n(x)
I know that whether a Legendre Polynomial is an even or odd function depends on its degree.It follows directly from the solution of Legendre differential equation.But,to prove these properties I am getting stuck.
Can anyone help me to start with these?
I referred to those webpages earlier.They contain results but no derivation.
How can I use (-x)^a=(-1)^a*(x)^a within a series?
As Astronuc suggested, substitute as (-x)a for each term in the series. What can you say about (-1)n-2m when m varies?
OK,I already got it.
One should exploit the property: P_n(x) even and odd according as n is even and odd.
The statement you are going to prove can be seen readily if you look at the Ridrigues' formula of Lengreda Polynomial, isn't it? :wink:
I am interested to know how the first formula can be derived from Rodrigues's formula.Is the Replacing x by -x should affect (d^l/dx^l)?If so,how?
Actually it appears...but not quite sure,how?
just change x-> -x
then the Rodrigues's formula has d/d(-x)
which can be rewritten as dx/d(-x)*d/d(x) , like changing variables as usual
then d/d(-x) = -d/dx and d^n/d(-x)^n = (-1)^n d^n/dx^n
for the question how the Rodrigues's formula came from...
i have no idea at all...:confused:
I anticipated something like this.Thanks for clarification.
  • · Replies 16 ·
