Two Resistance Problems (Circuits)
The discussion revolves around two problems related to electrical circuits, specifically focusing on resistor configurations in series and parallel setups. The first problem involves correcting a resistor value in a circuit, while the second problem compares power usage between series and parallel connections with given resistances.
  • Mixed
  • Participants explore calculations related to resistor values and power equations. There is an attempt to clarify discrepancies in the expected answers for the first problem and a discussion on the setup for the second problem, including different interpretations of power relationships in series and parallel circuits.
Some participants have provided insights and corrections regarding the calculations, particularly for the first problem. There is an ongoing exploration of the second problem's setup, with differing interpretations of the power relationship between series and parallel configurations. No consensus has been reached yet.
Participants note potential confusion regarding the resistor values used in calculations and the assumptions made about power relationships in different circuit configurations. There is an acknowledgment of the complexity involved in solving the problems without complete solutions being provided.
AngeloG
15. (II) A close inspection of an electrical circuit reveals that a 480-Ω resistor was inadvertently soldered in the place where a 320-Ω resistor is needed. How can this be fixed without removing anything from the existing circuit?
16. (II) Two resistors when connected in series to a 110-V line use one fourth the power that is used when they are connected in parallel. If one resistor is 1.6-kΩ, what is the resistance of the other?
P=IV
V=IR
Rt (series) = R1+R1...
Rt (paralell) = (1/R1 + 1/R2...)^-1
http://img362.imageshack.us/img362/3694/problems1mf2.th.jpg
This isn't homework; just going through every problem in my Physics book for the upcoming exam =p.
For 15, the back of the book says it's 960-Ω, not sure why? I'm getting a different answer. Maybe someone can clarify as to why.
For 16, I'm pretty sure I did it completely wrong heh =p.
P=IV, I = V / Rt
P(series) = 4*P(parallel)
(V/Rts) * V = 4*[ (V/Rtp) * V ]
Rts = 1600-Ω + x-Ω
Rtp = [(1/1600-Ω) + (1/x-Ω) ]^-1
V^2 / Rts = 4*[V^2/Rtp]
Solving for X, Maple spits out --> -1400-200*I*sqrt(15), -1400+200*I*sqrt(15) Which both seems extremely highly unlikely =p.
Well for question 15, you used 420 ohms instead of 480 ohms in your calculation!
Doh! Haha, that could be the problem =p.
It helps to read carefully :s.
I read it as P(series) = 0.25*P(parallel), which is the other way around from what you have. I have a solution, here's how I set it up:
For series circuit:
Since the current will be the same in both resistors, the power can be expressed as
[tex]P = I^2R = I_s^2(R_1 + R_2)[/tex] where Is is the current in the series circuit.
For the parallel circuit:
The voltage across each resistor will be the same, so the total power will be (with a little simplifying)
[tex]P_p =\frac{V^2}{R_1} + \frac{V^2}{R_2} = \frac{V^2(R_1+R_2)}{R_1R_2}[/tex]
You will also need to use the relation [tex]V=I_sR_T = I_s (R_1+R_2)[/tex]
Since the power used by the series circuit is 0.25 that of the parallel, you can relate the two expressions and solve for R2. No Maple should be needed!
  • · Replies 31 ·
