Is the Emf in a Coil of 100 Turns 0 When B Field Decreases from 1.0 T?
The discussion clarifies that the electromotive force (emf) in a coil with 100 turns, placed in a magnetic field of 1.0 T, does not equal zero when the magnetic field decreases from 1.0 T to 0 over 16 seconds. According to Faraday's law of induction, the emf is proportional to the rate of change of magnetic flux, which remains non-zero during the reduction of the magnetic field. The magnetic flux through the coil changes as the magnetic field decreases, resulting in a constant emf until the field reaches zero.
  • Understanding of Faraday's law of induction
  • Knowledge of magnetic flux and its calculation
  • Familiarity with electromotive force (emf) concepts
  • Basic principles of electromagnetism
  • Study the mathematical formulation of Faraday's law of induction
  • Explore the relationship between magnetic field strength and magnetic flux
  • Investigate the effects of coil turns on induced emf
  • Learn about the applications of electromagnetism in electrical engineering
Students of physics, electrical engineers, and anyone interested in understanding the principles of electromagnetism and electromagnetic induction.
tandoorichicken
Please tell me if this is right:
A coil contains 100 turns of wire in a loop 15cm in diameter. The loop is placed between the poles of a large electromagnet B= 1.0 T, with the plane of the loop perpendicular to the field. If the magnetic field is steadily reduced from 1.0 T to 0 in 16 seconds, is the emf in the coil = 0?
I can tell you that it's definitely not 0, not in the first 16 seconds that is.
[tex]\epsilon ' = \frac{d\phi B}{dt} = \frac{dBS}{dt}[/tex]
S, the area, stays constant but B, the magnetic field, reduces constantly. So the magnetic flux through the coil changes and therefore there is EMF in it.
Yes, the emf in the coil will be 0 when the magnetic field decreases from 1.0 T to 0 in 16 seconds. This is because the emf (electromotive force) is directly proportional to the rate of change of magnetic flux through the coil. When the magnetic field decreases, the magnetic flux through the coil also decreases, resulting in a decrease in emf. Since the decrease in magnetic field is steady and the rate of change of magnetic flux is constant, the emf will also be constant and equal to 0. This can be calculated using Faraday's law of induction, which states that the emf induced in a coil is equal to the negative of the rate of change of magnetic flux through the coil. Therefore, in this scenario, the emf in the coil will be 0.
  • · Replies 19 ·
