Does Eric's Leap Clear the Puddle?
  • Thread starter Thread starter KingNothing
    Numbers
The discussion revolves around projectile motion, specifically analyzing the jump of a character named Eric over a puddle and the trajectory of a golf ball hit over a certain distance. Participants are exploring the calculations related to horizontal and vertical motion in these scenarios.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the time of flight for Eric's jump and its impact on the horizontal distance covered. There is also a transition to a different problem involving a golf ball, where questions arise about determining initial velocity from given distance and time.
Some participants are providing calculations and equations related to the problems, while others are questioning the assumptions made, such as the time of flight and the interpretation of horizontal distance. There is an ongoing exploration of how to set up simultaneous equations for the golf ball problem.
Participants are working within the constraints of homework problems, which may limit the information available for solving the questions. There is a focus on ensuring the correct application of physics principles in both scenarios.
KingNothing
Sorry, this is extremely basic for most of you so thanks for even reading this...
"Eric is running to school and leaping over puddles as he goes. From the edge of a puddle 1.5 m long, he jumps .2 m high off the ground with a horizontal velocity of 3 m/s. WIll he land in the puddle?"
I said: .2=4.9t^2
.04...=t^2, t=0.2 s
0.2*3=0.6, 0.6 < 1.5 therefore, yes he will hit the puddle.
The total time of the jump is actually [tex]2t[/tex], so the horizontal distance is 1.2 meters. Still, he won't make it over the paddle.
Thanks Chen, I almost forgot t is just for one direction.
I have a question on this one too:
"A golf ball is hit, it travels 155 yards before hitting the ground 3.2 seconds later. What was it's initial velocity?"
Now, I found the height to be about 12.5 yards, but I don't know where to go from there.
Just make 2 simultaneous equations.
I'll write the distances x3 (3 feet in a yard i think).
horizontal distance (solve for velocity):
[tex]d_x = V_xt[/tex]
[tex]d_x = Vcos(\theta)t[/tex]
[tex]V = \frac{d_x}{tcos(\theta)}[/tex]
vertical distance (solve for velocity):
[tex]d_y = V_yt + \frac{1}{2}at^2[/tex]
[tex]0 = Vsin(\theta)(t) + \frac{1}{2}at^2[/tex]
[tex]V = \frac{-at}{2sin(\theta)}[/tex]
Now if I did those right, this should work. Make the equations equal to each other and try to solve for theta (the angle)
[tex]V = V[/tex]
[tex]\frac{d_x}{tcos(\theta)} = \frac{-at}{2sin(\theta)}[/tex]
[tex]tan(\theta) = \frac{-at^2}{2d_x}[/tex]
[tex]tan(\theta) = \frac{-(-32.2)(3.2)^2}{2(465)}[/tex]
[tex]\theta = 19.52[/tex]
Now back to the first equation
[tex]V = \frac{465}{(3.2)cos(19.52)}[/tex]
[tex]V = 154.17 \frac{ft}{s}[/tex]
So the answer would be 154.17 ft/s at 19.52 degrees from the horizontal.
Remember how to solve for simultaneous equations, it will come back to haunt you.
  • · Replies 38 ·
  • · Replies 35 ·
17K
