How are Energy and Momentum related?
  • Thread starter Thread starter AznBoi
    Energy Momentum
The discussion revolves around the relationship between energy and momentum, particularly in the context of collisions. Participants explore how kinetic energy and momentum are defined and how they interact during different types of collisions.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants attempt to relate kinetic energy and momentum through their mathematical expressions, questioning how one can derive kinetic energy from momentum. There are discussions about the conservation of momentum and energy in elastic and inelastic collisions, as well as the implications of these principles in solving problems involving collisions.
The discussion is ongoing, with participants providing insights into the relationships between energy and momentum. Some guidance has been offered regarding the use of conservation laws in collision problems, but there is no explicit consensus on the methods or interpretations being discussed.
Participants note that the relationship between energy and momentum may vary depending on the type of collision (elastic vs. inelastic) and highlight the importance of understanding the underlying principles of conservation in physics problems.
AznBoi
I know that both energy and momentum are transferred from one object to another in collisions. But I'm not use to relating energy to collisions, rather I use momentum mostly. How are Energy and momentum related? I know that Kinetic energy has the same variables (mv) as momentum except that it has the extra (1/2) and squared sign on the mass.
e= p^2 / 2m ...here e is energy...p is momentum...and m is mass(either of the system or the body)...
so in order to get KE can you just mutiply momentum by 1/2m?? I know that E=pc.. but I haven't really looked into relativity yet. lol
It is actually the velocity that is squared, not the mass as in 1/2mv^2.
It is no longer a vector quantity unlike momentum. Generally, momentum is always conserved in the absence of an external force, where as energy may or may not be. So in the case of a simple collision that's elastic, energy is conserved, whereas in one that is inelastic, it is not.
In some simple collisions such as where objects stick together, it is enough to use conservation of momentum. In others, even fairly simple ones, such as the following:
a small block of mass m moving at velocity, v, collides with a heavier block of
mass 3m, find the final velocities of each block.
Using conservation of momentum,
mv=m*v1+3m*v2
Two unknowns, one equation. A dead end. Thats where conservation of energy comes to the rescue, it gives us another equation so that both v1 and v2 can be solved for. That help at all?
mv=m*v1+3m*v2
Thanks for your explanation. =] So can you just multiply the momentum of an object by (1/2)v to get its scalar Kinetic energy? Does this multiplying/dividing subtracting method work for all equations?
Maybe looking at the relationships between the different quantities may help.
F=dP/dt so P=integral of force wrt time, p=F*t
Work=Integral (force*cos(theta)dx), under "ideal" conditions= F*distance
Work (in absence of dissipation such as friction and change in potential energy)=kinetic energy
so P*distance/time=KE
So there are a lot of constraints. But yes, if you wanted to know the kinetic energy of a constant mass with a particular momentum, you could multiply by v/2. Was there a particular example of a problem you had in mind?
That might be more hepful.
