| Thread Closed |
Math-related Physics question. |
Share Thread |
| May9-07, 09:34 AM | #1 |
The electric charge of an electron is -1.6 x 10(to the -19th power) C. What is the force exerted between two electrons separated by one meter? (Be sure to note whether the force is attractive or repulsive.) Show your calculations. 2. Relevant equations This is the equation I've been trying to use to solve it. F= K q1q2/d squared 3. The attempt at a solution I set up the equation and everything but I couldn't figure out the answer. The powers are confusing me. And I know that it is going to be labeled in Newtons but I don't understand how. 9.0 x 10(to the 9th power) N x m(squared)/c(squared) is what I used for K. Is that right? Any help would be great. Thanks. -natalia |
| May9-07, 09:42 AM | #2 |
Mentor
The magnitude of the force between two charged particles is [tex]F=k\frac{|q_1||q_2|}{d^2}[/tex]. Your value of k is correct. So, plugging in the values for the charge of an electron into this formula for q_1 and q_2 should yield the result.
Now, to answer your question re: units. K has units N m2C-2, so let's plug the units into the equation [tex][F]=\frac{Nm^2}{C^2}\cdot\frac{C\cdot C}{m^2}=N[/tex] and thus we see that the units of F are indeed Newtons, as required. Finally, intuition should tell you whether the force is repulsive or attractive. If two particles both have negative charge, will they attract or repel one another? |
| May9-07, 09:48 AM | #3 |
Thank you. This helps a lot.
| Thread Closed |
Similar discussions for: Math-related Physics question.
| Help:>> Lawn Mowing Question Physics related | Introductory Physics Homework | 3 | ||
| [Discrete Math] <=> related question. | Calculus & Beyond Homework | 15 | ||
| Another chem related math question | General Math | 1 | ||
| Resources to understand physics-related math? | General Physics | 4 | ||
| [SOLVED] A physics related computer question | General Physics | 1 | ||
