My air conditioning doesn't cold
The discussion centers on the air conditioning system of a 1997 Dodge Neon, specifically regarding the pressure (PSI) required for the suction side of the air conditioner compressor during refrigerant recharge. Participants emphasize the importance of consulting the vehicle's shop manual for accurate recharge procedures and pressure specifications. They also suggest that if the system requires refrigerant, it may indicate a leak, and recommend considering professional service for the recharge to avoid potential issues.
  • Understanding of automotive air conditioning systems
  • Familiarity with refrigerant types and charging procedures
  • Knowledge of pressure measurement in PSI
  • Access to a vehicle shop manual for the 1997 Dodge Neon
  • Research the specific refrigerant type used in the 1997 Dodge Neon
  • Learn about automotive air conditioning leak detection methods
  • Study the proper refrigerant recharge procedure for the Dodge Neon
  • Compare costs and services of local automotive shops for AC recharge
Car enthusiasts, DIY mechanics, and anyone looking to maintain or troubleshoot the air conditioning system in a 1997 Dodge Neon.
omaremanuels
Hello everybody! i have a dodge neon 97 and i want to know how much pressure (PSI) receive the charge suction of the air conditioner compressor system? because i wan't to put the gas refrigerant recharge by myself
Probably not a good idea and not something we could know.
If it needs refrigerant, it probably has a leak...
You would need to read the shop manual for your vehicle to see what the recharge procedure is for it. The shop manual is available at most auto parts stores, or from your local Dodge dealer. But it may be cheaper to have a shop do the recharge for you, rather than buying the shop manual -- you could check and compare the prices.
  • · Replies 18 ·
9K
21K
  • · Replies 21 ·
  • · Replies 45 ·
