Is it better to leave computer on all day or to turn on and off?
  • Thread starter Thread starter moe darklight
    Computer
The discussion centers around the question of whether it is better to leave a computer on continuously or to turn it on and off as needed. Participants explore various aspects including energy consumption, hardware longevity, and environmental considerations.
  • Some participants suggest that leaving a computer on 24/7 may be better for the hard disk compared to frequent power cycling.
  • Others argue that if a computer is not turned on and off frequently, there may not be significant benefits to leaving it on all the time.
  • Concerns are raised about wear on components such as fans and hard drives from continuous operation, while others mention potential damage to the motherboard from power surges during startup.
  • Energy costs associated with leaving a computer on continuously are debated, with differing estimates provided by participants.
  • Some participants advocate for turning off the computer when not in use to save electricity and benefit the environment.
  • There are suggestions that laptops may require different considerations than desktops regarding power management and hard drive longevity.
  • One participant notes that computers generally need periodic reboots, particularly if running Windows.
Participants express multiple competing views regarding the impact of leaving a computer on versus turning it off, and the discussion remains unresolved with no consensus reached.
Participants reference varying energy costs and assumptions about hardware longevity, which may depend on specific usage patterns and definitions of "on" versus "off." There are also differing opinions on the impact of sleep mode on hardware wear.
moe darklight
Hey, I heard somewhere that leaving the computer on 24/7 is better for the disk than turning it on and off as needed. is this true?
I tend to leave mine on for long periods of time when I'm using bit-torrent and uploading or downloading files. and I never really turn it off, I usually just put it to sleep when I'm not going to be using it.
Computer science news on Phys.org
Unless you'd be in the habit of turning it on and off several times a day, you don't gain much by leaving it on all the time. If you had it off half the time but also cut it's lifespan in half, it'd still last the same number of years and would cost half as much to operate.
At residential energy rates, it costs about $30 a month or $360 a year to leave a computer on 24/7.
Also, sleep mode wouldn't help you since the concern (ill-conceived or not) is that in starting-up the computer, the warm-up can damage it. And a computer brought out of sleep mode still starts cold.
We've actually discussed this several times before...
Well if you leave it on all the time you tend to wear out the all the fans and probably your hd to. Whereas if you turn your computer on and off often I've heard that it wears out the motherboard, due to the power surge it gets every time you turn it on. ( but I would consider that latter more heresay, I read it on a computer forum once but am not really sure if it is true.)
so pretty much, either way it won't affect the longevity and performance of my computer?
I think this is erroneous. If you're paying $0.10 per kWh (which is rather high), a 150 Watt computer would only cost you $10.80 per month.
- Warren
Save electricity! Turn off the computer when it is not in use. It not only saves money but is also good for the environment.
However, if you would rather leave it turned on the put it to use! Look up www.hardfolding.com[/URL] and put that idle cpu to good use curing diseases!
- Warren
$.10 for residential is unusually low, though it does depend on where you live. I typically use $.13 in calculations for residential (and I did here), but looking it up, it is actually $.15 for the first 500 kWh and $.17 for each additional (including 6% sales tax). That's a lot higher than I realized. Here's the rate (pdf page 37):
http://www.exeloncorp.com/NR/rdonlyres/71890D18-6BF8-4F13-A998-298A22A4D995/3147/s71_completeUpdate.pdf
150 watts for an idling computer seems pretty low to me, but I haven't put mine on a wattmeter and it of course depends on the computer.
However, if you would rather leave it turned on the put it to use! Look up www.hardfolding.com[/URL] and put that idle cpu to good use curing diseases![/QUOTE] Actually, computers use considerably more energy when their processor is active than when they are idle.
If your computer is a laptop, I suggest putting it to sleep like you are. Laptop HDs do not have the longevity that desktop models have.
If it's a desktop, I think the only thing you really need to worry about s the monitor. If you have an energy star compliant monitor, you should have a setting in your power management to shut the monitor off after a time period of inactivity.
http://computer.howstuffworks.com/question328.htm
Assuming your computer is running Windows, it's going to need a reboot every now and then anyway.
19K
12K
  • · Replies 32 ·
  • · Replies 69 ·
  • · Replies 17 ·
  • · Replies 22 ·
