Is the gas monatomic or diatomic?
  • Thread starter Thread starter imy786
    Gas
The problem involves determining the molar heat capacities of an ideal gas when a specific amount of energy is supplied as heat at constant pressure, alongside a query about whether the gas is monatomic or diatomic.
  • Participants discuss the calculation of molar heat capacity at constant pressure and volume, with one participant attempting to derive values based on given equations. Questions arise regarding the relationship between Cp and Cv, and the meaning of specific terms in the equations.
There is an ongoing exploration of the relationships between heat capacities and the ideal gas law, with participants offering guidance on how to approach the calculations. Multiple interpretations of the equations are being examined, and participants are questioning the definitions and implications of the variables involved.
Participants are working under the constraints of the problem statement, which specifies the energy supplied, the number of moles, and the temperature change, while also considering the nature of the gas in question.
imy786
130 J of energy is supplied as heat to 3.00 moles of an ideal gas at constant pressure, the temperature rises by 4.00 K.
Calculate the molar heat capacity at constant pressure, CP,m and the molar heat capacity at constant volume, CV,m for the gas.
Cp= Q/ T
Cp= Cv + nR
Cp,m = Cv,m +R
Cp= Q/ T
= 130/ 4= 32.5
Cp= Cv + nR
32.5 = Cv +3 (8.314)
Cv= 7.558
heat capacity at constant pressure Cp = 32.5
at capacity at constant volume Cv = 7.558
how do i go from here to calculate molar heat capacity..
Divide Cp by the number of moles. Generally speaking, [tex]Cp=\frac{pdv}{ndt}+Cv[/tex] where Cp and Cv are molar heat capacities at constant pressure and volume.
Cp = nR + Cv
is nR= pdv/ ndt
what is dv/dt that u have in your formula...is the rate of change of volume...
or volume / temperautre?
Volume by temperature. You can use the ideal gas equation, PV=nRT, to find it under what ever conditions that are imposed on your system.
24K
