Calculating Angular Acceleration of Bicycle Wheels
The discussion focuses on calculating the angular acceleration of bicycle wheels with a diameter of 1.2m as a bicyclist accelerates from rest to 24km/h in 14 seconds. The linear speed is converted to 6.7m/s, leading to an angular velocity of 11.2 rad/s. The angular acceleration is determined using the formula a = (delta w)/t, resulting in an angular acceleration of 0.8 rad/s². The calculations are confirmed to be accurate, adhering to significant figure rules.
  • Understanding of angular motion and acceleration
  • Familiarity with the relationship between linear and angular velocity
  • Knowledge of significant figures in scientific calculations
  • Basic proficiency in using formulas for tangential and angular acceleration
  • Study the relationship between linear and angular motion in physics
  • Learn about the application of significant figures in engineering calculations
  • Explore the concept of tangential acceleration and its relation to angular acceleration
  • Investigate the dynamics of bicycle motion and factors affecting acceleration
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of bicycle motion and angular acceleration calculations.
cristina
A bicycle has wheels of 1.2m diameter. the bicyclist accelerates from rest with constant acceleration to 24km/h in 14.0s. What is the angular acceleration of the wheels?
If the bicycle is going forwards relative to the ground with a speed of 24km/h, then, all points on the tread are moving around the wheel with a speed (s) of 24km/h relative to the axel.
s = 24km/h = 6.7m/s (I know the significant figures rules but I don't know where to round)
r = 1.2m/2 = 0.6m
w=s/r
w=6.7/0.6 = 11.2 rad/s ( is my rounding correct here?)
a=v^2/r=(6.7)^2/0.6= 74.8m/s^2
Is the reasoning correct?
Thank you for your help.
A number in the problem has three digits (12.0), so that is what your answer should have at most, also.
The number 6.7/0.6 ought to have just 2 figures, but since the first number really should have 3 figures in the first place, and the second number is accurate to 3 figures, . . .
Tangential acceleration = angular acceleration * radius
is another formula you could use to check your work, which I only eyeballed. Looks OK to me.
r = 1.2m/2 = 0.6m
This is corect
w=s/r
This is correct
The question asks for angular acceleration.
a = (delta w)/t
a = (11.2)/(14)
a = 0.8 rad/s^2
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 19 ·
