Projectile motion w/drag equations
The discussion revolves around deriving the maximum distance of a projectile considering air resistance, with a focus on the effects of initial velocity and launch angle. Participants explore the equations governing projectile motion, particularly in the presence of drag forces.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the equations for drag forces acting on horizontal and vertical components, questioning the assumptions behind these equations. There are attempts to derive a function for horizontal distance based on initial conditions and the effects of air resistance.
Some participants have offered guidance on how to approach the problem, suggesting methods to account for air resistance in the equations. There is an ongoing exploration of the relationships between the variables involved, with no clear consensus on the feasibility of deriving a closed-form solution.
Participants note the complexity introduced by air resistance and the challenges in integrating the equations of motion. There is a recognition of the need for numerical solutions as an alternative to closed-form expressions, given the difficulties encountered in the analytical approach.
Mag|cK
Hello. How do we derive:
Maximum distance of a projectile as a function of initial velocity and launch angle. [taking into account the air resistance] Assuming mass of projectile, air viscosity, drag coefficient, etc are constants.
Is there any sites giving the steps?
I have another question: I have researched that
for horizontal component (x), Fdrag= -0.5 C p A V Vx
for vertical component (y), Fdrag= -0.5 C p A V Vy
where V=square root(Vx^2+Vy^2)
Isn't Fdrag for horizontal component is simply= -0.5 C p A Vx^2
and for vertical component, Fdrag = -0.5 C p A Vy^2 ?
The horizontal and vertical drag components will depend on the angle, surely ?
Can you find the distance flown when there is no drag ?
yes i can. I have found the answer to my second post. Any answers on my first post?
Hm, I don't see any distances in your answers, or angles. Shouldn't you consider a projectile thrown with initial angle theta, and velocity V ?
This might help -
http://physics.gmu.edu/~amin/phys251/Topics/ScientificComputing/sprojectileMotion.html
I think you are talking about projectile motion without air resistance?
Nonetheless, in projectile with air resistance, is it possible to obtain an equation of maximum distance as a function of initial velocity and launch angle (as the variables only)?
A good approach would be to write the equation for the maximum distance as a function of V and theta, then add terms to the derivation to account for air resistance. To get the maximum range you work out the time the projectile is in the air from the vertical component, then multiply that time by the horizontal velocity. If there's air resistance, the time in the air becomes a tricky calculation.
If there's air resistance it will enter the formula.
It's not that simple as horizontal velocity is changing due to air drag.
And btw why is this thread moved? I really don't think this is introductory physics.
Who said it was simple ? The drag is obviously going to affect both components. Why don't you have a shot at it ? I'm willing to help if you show some work. You could also try looking for notes on the web.
I want to integrate
dVx/dt = -(D v Vx) / m
but v=sqrt(Vx^2+Vy^2)
I have tried substitution method to eliminate Vy, but it's not possible (I have done this for hours).
My question is,
Is it even possible to come up with an equation of horizontal distance as a function of launch angle, initial velocity and time?
I cannot say for sure no, but I didn't see any such function so far.
However, I wonder why you need the closed form? If it is a goal unto itself, well... But if you need to compute this as part of some other problem, numeric solution can be easily constructed in many ways. The details are nicely presented in the link given by Mentz114.
Chusslove Illich (Часлав Илић)
Well I have a set of equations, only based on that Fdrag= -0.5 c p a v^2. I just divide into horizontal and vertical component, mainly the force and acceleration. However to find the function of horizontal distance, I believe I have to integrate dVx/dt and then integrate it again.
While combining the equations (hoping that I can eliminate the unknown variable), I found a strange inconsistency in the equations:
(A=acceleration)
Fx= -D v^2 cosX = -D v Vx
Fy= -D v^2 sinX - mg = -D v Vy -mg
F=sqrt(Fx^2+Fy^2)
A=dv/dt= [sqrt(Fx^2+Fy^2)] /m ---------------[1]
v=sqrt(Vx^2+Vy^2)
dv/dt= (Vx Ax + Vy Ay)/ sqrt(Vx^2+Vy^2) --------[2]
Solving [1]=[2], they are not equal and after solving [1]=[2], I found that Vx=0 for [1] and [2] to be equal. Yet Vx is obviously not 0.
Can anyone explain why? I know they are time-consuming to solve (not difficult though). Thnx.
Your expression [2] is not an equation, but an indentity: left hand side is acceleration component in direction of velocity, right hand side is the same, only using scalar product formulation.
Equation [1] is wrong: left hand side is same as in [2], but right hand side is full acceleration, not only the component in velocity direction. The corrected [1] would be alike [2]:
[tex] \frac{dv}{dt} = \frac{v_x F_x + v_y F_y}{\sqrt{v_x^2 + v_y^2}} \frac{1}{m}[/tex]
But with [2] being identity, [1] and [2] would only assert:
[tex] a_x = \frac{F_x}{m}, \quad a_y = \frac{F_y}{m}[/tex]
and you're back to square one.
What's the difference between identity and equation?
So it's not possible to integrate and come up with distance equation?
(I may not be using proper mathematical terms, so sorry for any confusion.)
Identity is something that is true by definition, so it cannot provide any links between the independent quantities in a particular problem. Equation is a constraint on the problem imposed from outside, e.g. by physical laws. Thus, your expression [1] comes from 2nd Newton law (an equation), whereas [2] comes from definitions of tangential acceleration and vector product (an identity).
I cannot claim that it is not possible (math is not my strong point), I just haven't seen any such integration.
28K
