Thread Closed
Lens system
Share Thread Thread Tools
May21-07, 08:01 AM   #1
Lens system
A combination of two thin convex lenses of equal focal lengths,is kept separated along the optic axes by a distance of 20 cm between them.The combination behaves as a lens system of infinite focal length.If an object is kept at 10 cm from the first lens,its image will be formed on the other side at a distance x from the second lens.Find x.
2. Relevant equations
1/f=1/v + 1/u
where f is focal length,u is object distance and v is image distance.
3. The attempt at a solution
Can the above equation be applied for the lens system as a whole,instead of just a single lens at a time? If it can be applied,then I think the problem can be solved in the following way:
Since f of the lens system is infinity,this means that rays initially travelling parallel to the axis before the 1st lens,will continue to do so after passing through 2nd lens.The lens system behaves symmetrically.If we apply the above equation to the system as a whole,we get v= -10 cm and the image is virtual.Therefore x= 1o cm.Is this answer and reasoning correct?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
May23-07, 10:41 AM   #2
Someone please help........
May23-07, 11:51 AM   #3
Hello,
I have tried to prove some relation that you want by some simple assumptions: (1)two identical lenses (2)the curvatures of two surface of one lens are the same (3) lenses are thin. But no such a general relation is satisfied. More intuitively, you can consider some special examples with the lenses of the problem:
Example1.
an point object is in front of the first lens with [tex]p_1=25\text{(cm)}[/tex]
(i guess that you can calculate about the image problems with Gauss' formula)
[tex]\frac{1}{25}+\frac{1}{q_1}=\frac{1}{10}\quad\Rightarrow\quad q_1=\frac{50}{3}\text{(cm)}[/tex]
[tex]p_2=20-\frac{50}{3}=\frac{10}{3}[/tex]
[tex]\frac{1}{10/3}+\frac{1}{q_2}=\frac{1}{10}\quad\Rightarrow\quad q_2=-5\text{(cm)}[/tex]
Therefore the image is a virtual one and between the two lenses with a distance 5(cm) from the second lens.
If one calculates again with your point of view, one always gets the same image distance with the distance between the object and the first lens (due to the infinite forcus length).
Example2.
an point object is in front of the first lens with [tex]p_1=20\text{(cm)}[/tex].
You can try this example without calculations.
Therefore, the problem is just a coincidence.
Hope these helpful.
May24-07, 03:49 AM   #4
Lens system
I don't quite understand.
Thread Closed
Thread Tools
Similar Threads for: Lens system
Thread Forum Replies
"Lens 1.0" - the decision of the problems on optical lens Programming & Comp Sci 0
Focal length of concave lens using convex lens Introductory Physics Homework 3
Patriot Missles system failures & the metric system Computing & Technology 16
A lens system. General Physics 8
the difference between system equili and system and steady state General Physics 4
