| Thread Closed |
fans in CPU ? |
Share Thread |
| May22-07, 04:21 AM | #1 |
fans in CPU ?
Hi all,
I just opened my desk PC case for cleaning. There are fans, one in the power supply and one over the CPU. Do I need to oil the fans and what kinds of oils are suitable for this purpose? Thanks |
| May22-07, 04:27 AM | #2 |
The fans in your computer almost assuredly use sealed bearings and cannot be oiled. If a fan is making noise, it's because the bearings are shot, and the entire thing needs to be replaced. They're cheap.
- Warren |
| May23-07, 12:41 PM | #3 |
Don't oil them, chances are you'll spray oil everywhere, dust will stick to it, and you'll have no end of grief.
| May25-07, 02:03 AM | #4 |
fans in CPU ?
It's a good idea to replace the cpu fan before it is worn out. What could happen if the bearing is worn out, espessially if it it a low speed fan, is that the destroyed bearing will lock up the fan, so that the processor will be destroyed.
| May26-07, 09:20 PM | #5 |
I dont see the problem with oiling the fans if you know what you are doing. Here is a good tutorial:
http://www.dansdata.com/fanmaint.htm Oiling your old fans increases the chance they will last longer, and might actually improve efficiency/lower noise too. |
| Jun2-07, 06:08 PM | #6 |
| Thread Closed |
Similar discussions for: fans in CPU ?
| Any Tina Fey fans? | General Discussion | 7 | ||
| Consecutive fans | General Physics | 4 | ||
| Hip Hop Fans | General Discussion | 8 | ||
| Domestic fans....please help! | General Discussion | 4 | ||
| shouldnt the wind generated from the fan blow the dust away | Biology | 10 | ||
