| Thread Closed |
Nothing can exceed the speed of light |
Share Thread | Thread Tools |
| May22-07, 02:35 PM | #1 |
Special relativity tells us information can not be sent faster than the speed of light. I believe Einstein, but was curious what people thought about the following thought experiment:
The nucleus of an atom has a particular width. With sufficiently advanced technology I could setup a detector that detects motion at the far side of a nucleus. I should be able to “bump” the nucleus from the front side and detect the movement on the back side. One of two things will happen. 1. The detector will instantaneously detect the movement. This would occur if the nucleus is dense and non-elastic. This would reveal an exception to the “cannot transmit information faster than light” rule (albeit at a very small scale). 2. The detector will NOT instantaneously detect the movement. This reveals the dense nucleus itself behaves in a wave like fashion. I'm an amateur so my question may not even be valid, but I welcome any feedback. |
| May22-07, 02:44 PM | #2 |
Recognitions:
The modern view is that a nucleus is really made up of three quarks, so your example doesn't quite work. But we can generalize a bit.
It's possible to view quantum mechanical particles as particles, but it's just as possible to view them as waves. When viewed as waves, the waves propagate at 'c'. (For instance, in QED). When viewed as particles, the quantum mechanical particles do NOT have a size - you need to think of them as being points. We've actually sidestepped a few tricky issues of interpretation, but these would probably best go in the QM forum. The only coherent interpretation of quantum systems as particles that I'm aware of has the rather odd property that the particles have multiple histories. |
| May22-07, 09:41 PM | #3 |
The one thing you CAN'T do is treat atoms as little spheres with a diameter.
| May23-07, 05:01 AM | #4 |
Recognitions:
Without referring to the specific proerties of a nucleus, there is generally no rigid material in relativity, as a matter of principle.
| May23-07, 08:59 AM | #5 |
Mentor
Pervect, DaveC426913, and Ich have all made good points.
For simplicity, consider a normal hydrogen atom that has one positively charged proton as its nucleus. This distribution of positive charge doesn't have an edge, it sort of fades away. Getting an extremely accurate handle on the exact form of this fade is a subject of current research. Also, this charge distribution is not rigid. In fact, quantum theory shows that there is a small but non-zero probability that hydrogen atom's electron will be found inside the proton! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Nothing can exceed the speed of light
| Can something exceed the speed of light? | General Physics | 4 | ||
| Why can't a photon exceed the speed of light? | Special & General Relativity | 18 | ||
| How To Exceed The Velocity Of Light 2 | General Physics | 9 | ||
| How To Exceed The Velocity Of Light 1 | General Physics | 0 | ||
| Catch the neutrino speed exceed light | General Physics | 1 | ||
