One more question A trampoline and potential energy
The problem involves a trampoline artist jumping from a platform and the energy transformations involved as he depresses the trampoline, modeled as a spring. The subject area includes concepts from mechanics, specifically potential energy, kinetic energy, and spring dynamics.
  • Participants discuss the relationship between gravitational potential energy and kinetic energy in the context of the trampoline's behavior. There is an exploration of how to incorporate the artist's initial velocity into the energy equations.
Some participants have provided guidance on adjusting the energy equations to account for both potential and kinetic energy. There is acknowledgment of a mistake regarding the initial conditions, and a revised equation has been suggested, though further clarification on the implications of the initial velocity is still being sought.
Participants are navigating the complexities of energy conservation in a system where both gravitational and kinetic energies are present. There is an emphasis on ensuring all forms of energy are accounted for in the calculations.
MJC8719
A 75 kg trampoline artist jumps vertically upward from the top of a platform with a speed of 4.0 m/s. the tampoline is three meters below the platform.
(b) If the trampoline behaves like a spring of spring constant 5.2 104 N/m, how far does he depress it?
when he depressed the trampoline he also moved further downward. So the total change in height is H + x where H = 3.0 meters and x is the distance the trampoline is depressed, not just 3 meters
You can equate energy at the top, when he is motionless, with energy at the bottom, when he is also motionless.
So equating energy...
m g (H + x) = (1/2) k x2
You'll have a quadratic in x. Go ahead and plug in numbers:
75 * 9.8 * ( 3 + x ) = (1/2) * 52000 x2
2205 + 735 x = 26000 x2 ugly. you can div everything by 1000
26 x2 - 0.735 x - 2.205 = 0 and use quadratic eqn
x = ( 0.735 +/- (0.7352 - 4* 26* (-2.205) )1/2 ) / 2*26
x = ( 0.735 +/- 15.16 ) / 52 = -0.277, 0.306
The negative is not valid, so the answer must be 0.306 meters
Good.
But he's not motionless when he jumps from the platform; he's moving at 4.0 m/s.
Ok...I understand that I missed that but I do not know how I can account for it...Is it as simple as multiplying the mg(h+x) by 4 or is it more complicated...
Im guesssing I ignored that part since I am not to sure what to do with it lol
mg(h+x) is potential energy; why would you multiply an energy times a velocity?
Instead, realize that the initial energy is not just gravitational PE, but also KE.
Whoops..
So the original equation should read:
mg(h+x) + .5mv^2 (accounting for the kinetic energy) = .5 kx^2
Then just solve for x
That looks good.
12K
9K
