How is the Void Open in the Topology of R^n?
  • Context: Graduate
  • Thread starter Thread starter quasar987
The discussion revolves around the properties of the empty set (void) in the context of topology, specifically within the framework of R^n. Participants explore the definitions of open and closed sets, the implications of these definitions for the empty set, and the logical reasoning behind these properties.
  • One participant questions how the definition of open sets applies to the empty set, suggesting that since the void has no points, the definition may not apply.
  • Another participant argues that the definition does apply, stating that the statement "for all points in the void, we can find an epsilon-ball" is vacuously true because there are no points to contradict it.
  • Some participants clarify that the empty set is both open and closed, referencing the concept of vacuous truth in logic.
  • A later reply emphasizes that the definition of openness relies on a universal quantifier, which holds true for the empty set.
  • There is a question raised about the boundary of the empty set, with differing views on whether it is the void or the entirety of R^n.
Participants express differing views on the application of definitions to the empty set, with some asserting that the definitions hold true while others question their applicability. The discussion remains unresolved regarding the implications of these definitions and the nature of the empty set's boundary.
The discussion highlights the nuances of logical reasoning in topology, particularly regarding the definitions of open and closed sets and the concept of vacuous truth. There are unresolved assumptions about the implications of these definitions for the empty set.
quasar987
I'm not asking why it is an axiom of a topology that the void is open, but rather, when the topology of R^n is developped and open sets are defined as sets such that for any point in the set, we can find an epsilon-ball centered on that point that is entirely contained in the set.
My book says that it follows from the dfn that the void is empty. How is that? If we argue that "since the void has no point, then it is true that for all points, we can find and epsilon-ball, etc.", then the opposite is just as true: "Since there are no point, we can say that for all point, we can never find an epsilon-ball, etc."
There is no points in the void, so the definition simply does no apply it seems!Similar question: what's the boundary of the void? is it the void or the whole of R^n?
You're correct that both arguments are valid, but note that "Every point does not have X" is NOT the opposite of "Every point has X". In order for the null set not to be open, we would need that the contradiction of "Every point has X" hold, which is of course "there is a point which does not have X".
The definition always applies. Either every point has a property, or one of the points doesn't.
Well the null set is closed, so that ought to answer your question.
Ok, I see! Thx DW
No problem. It does sound like you might want to brush up more on your logic if you intend to study mathematics at this level.
This has been my conclusion as well :smile:
consider a statement of form "for all elements of set S, property P is true".
If S is empty this statement is true, :"vacuously".
this aNSWERS YOUR QUESTION, say in a metric space. i.e. openness is defined by a ":universal" quntifier: "for all p in S, there is an open ball around p also contained in S".
S contains all its limit points.
If rephrased (i.e., as a universally quantified implication) and taken as definition of closed set in a metric space, we arrive at same vacuous truth (i.e, antecedent false) wrt. empty set.
Empty set both open and closed.
10K
  • · Replies 16 ·
  • · Replies 61 ·
