What is the relationship between a rolling sphere and a smooth cloverleaf helix?
  • Context: Graduate
  • Thread starter Thread starter Loren Booda
    Dynamics
The discussion explores the relationship between a rolling frictionless sphere and the shape and slope of a smooth cloverleaf helix that guides the sphere back to its original direction at a height above a given point. The focus includes theoretical considerations of geometry, banking, and the dynamics of motion.
  • Some participants propose that any smooth curve that allows the sphere to reach a height h, satisfying the equation hg = (1/2)v², could work.
  • Others suggest that the shape of the cloverleaf must be characterized, potentially as a spiral or helix, and that the banking of the roadway is essential for the sphere to remain on track.
  • There is a discussion about the interdependence of the shape and slope of the track, emphasizing that a nonzero slope is necessary to prevent the sphere from sliding off.
  • Some participants argue that the banking angle is determined by the local curvature and the sphere's velocity, while others question how the shape affects the height the sphere can reach.
  • A later reply clarifies that if the sphere does not need to end up directly over its starting point, then various shapes could be considered, with the banking angle still dependent on curvature and velocity.
Participants express multiple competing views regarding the shape and banking requirements of the cloverleaf helix, and the discussion remains unresolved with no consensus reached.
Participants note the complexity of the problem, suggesting that it may not have a simple answer and that various assumptions about the shape and banking need to be clarified.
Loren Booda
Take a frictionless sphere rolling at speed v past a given point. What is the relationship between the shape and the slope of a smooth cloverleaf which guides the sphere to its original direction to rest a height h above the given point?
If it's really frictionless, then any smooth curve that takes the sphere to a height
h such that hg= (1/2)v2 will work.
Loren Booda,
If I understand your question, its describing one quarter of a highway cloverleaf, so in addition to the height that HallsofIvy showed you how to find, you also need a shape and size for the leaf (as viewed from above) and the banking of the roadway on the leaf.
Hint: What shape seems reasonable for the leaf if the sphere is going to roll around and get back to a point right over where it started? Characterize this shape with some paramter, say, R (that's another hint!). Now try working from there to find whether the roadway needs to be banked, and if so, by how much?
If you get stuck, post again, and I'll give you another hint.
Don't forget, "to rest".
jdavel,
I'm much too old for this to be homework! When traveling on a cloverleaf last night I considered this problem which you all are progressively formulating. It may not have a simple answer. A spiral comes to mind for the shape, but what then would be the banking?
Wouldn't the shape only change how you get to the top and not how high that top would be?
cookiemonster
As I first mentioned, the shape and slope of the track are interdependent and it is that relationship which we seek in terms of v and h. We want to prevent the ball from sliding off of the track, so a nonzero slope is necessary.
We should be able to calculate the velocity as a function of height. If we know the velocity at every point, we just have to have a horizontal slope that will yield a satisfactory normal force to create the proper centripetal acceleration. No?
cookiemonster
Sort of. A frictionless sphere needs a banked track to stay on track. At first glance, the banking's vertical component is a function of centripetal acceleration, the sphere's velocity squared over the immediate track curvature.
I'm not sure what you're getting at. Calculating the normal vector of a surface is a fairly simple matter, and calculating the necessary centripetal force isn't much harder.
cookiemonster
Loren Booda,
"A spiral comes to mind for the shape, but what then would be the banking?"
I misread your original question. I thought you had to end up at rest exactly over the point where you began. If not, any shape will do, with the banking angle determined by the local curvature and velocity.
(I should have said "helix" rather than spiral.)
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 62 ·
11K
