Focal length calculation and graph Q
by _Greg_
Tags: calculation, focal, graph, length
_Greg_
_Greg_ is offline
#1
Jun7-07, 09:46 AM
P: 38
Hi folks, just joined the forums
Hope you dont mind me firing a few questions now and again, i have some reports to do over the weekend which is the last of my HNC in Chemical Engineering
A lot of it is basic physics which iv done in the past but its just the odd bit that catches me out.
So anyway, iv done an expeiment with a converging lens where you alter the object distance and image distance ( U & V ) to get focused images on the screen.
With these results iv plotted a graph of V against U which produces a curved slope (diagram 1)
Click image for larger version
Name:	u and v.JPG
Then i done a graph of 1/V and 1/U which produces a straight line which intercepts the x and y axis, these values being 1/f (diagram 2)
My question is
Why is the graph of U and V not useful for finding the focal length of the lens accurately?
probably an easy question but i just cant put my finger on it
cheers
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
esalihm
esalihm is offline
#2
Jun7-07, 09:52 AM
P: 92
use similar triangles to proove that the formula for a lens is (1/U + 1/V = 1/f)
or u can find it anywhere on the internet. it is a very easy proof, won't take you 5 min.
therefore it is 1/U and 1/V not U and V
_Greg_
_Greg_ is offline
#3
Jun7-07, 10:24 AM
P: 38
not entirly sure what you mean, triangles?
anyway, that 1/V vs 1/U graph with my experimental results is proof that the equation is true.
im just asked why the U and V graph doesnt give an accurate value for the focal length?
esalihm
esalihm is offline
#4
Jun7-07, 11:31 AM
P: 92
ok
if you draw your object, lens and image on a piece of paper with two of the rays you use to draw a ray diagram, you can see that there are some similar triangles on that figure. Try using similar triangles and getting two equations involving U, V and f.
then solve them simultaneously to get "1/U + 1/V = 1/f "
(if you cannot I can give you the solution but try it first :)
U and V graph cannot give you an accurate value for the focal length because the relation between the two is not related to f in any simple way.
if u play around with the equation I gave you above you might get " "[(v+U)/U]*f=V" but this won't make it any easier.
perhaps the answer to your question is that the nature of lenses does not provide us with that simple relations where you plot U versus V and get a slope or a y intercept of f
Register to reply
Related Discussions
Focal Length General Physics 1
Focal length: cm-1? Introductory Physics Homework 4
focal length Introductory Physics Homework 2
focal length Introductory Physics Homework 8
focal length Introductory Physics Homework 0
