The total resistance of two wires, one with a resistance of 50 Ohms and a tolerance of 5%, and the other with a resistance of 60 Ohms and a tolerance of 3%, is calculated to be 110 Ohms. The total tolerance is determined to be 8%, derived from the individual tolerances and the error in the sum calculated using the square root of the sum of the squares of the individual tolerances. The resistance ranges for the wires are 47.5 Ohms to 52.5 Ohms for the first wire and 58.2 Ohms to 61.8 Ohms for the second wire, leading to a total range of 105.7 Ohms to 114.3 Ohms.
- Understanding of electrical resistance and Ohm's Law
- Familiarity with tolerance calculations in electronics
- Knowledge of statistical error propagation methods
- Basic proficiency in using square root calculations
- Research tolerance calculations for series and parallel circuits
- Learn about error propagation in electrical measurements
- Explore advanced resistance measurement techniques
- Study the impact of temperature on wire resistance
Electrical engineers, electronics technicians, and students studying circuit design and analysis will benefit from reading this discussion.
