Rear Differential Design: The Cause of Washboard Roads?
The discussion centers around the potential causes of washboard roads, particularly in relation to the design of rear differentials and suspension systems. Participants explore various factors that may contribute to the formation of these road conditions, including vehicle dynamics and road surface characteristics.
  • One participant suggests that the design of the rear differential may be responsible for washboard roads, noting the even spacing of the bumps.
  • Another participant proposes that suspension systems are more likely to be the cause of washboarding, indicating a preference for this explanation.
  • A different viewpoint highlights that washboarding can occur on unstable road surfaces, particularly at intersections, and theorizes that braking forces contribute to the effect.
  • One participant agrees with the idea that vehicle dynamics, including asymmetric loading on suspension and various factors like vehicle speed and road composition, play a significant role in the formation of washboards.
Participants express differing opinions on the primary cause of washboard roads, with no consensus reached. Some support the idea of suspension systems being more influential, while others maintain that the rear differential design could be a factor.
Participants mention various influencing factors such as vehicle weight, axle loading differentials, and road composition, but do not resolve how these interact or the specific conditions under which washboarding occurs.
zedex
After going up in the mountains where i live i started getting annoyed at how washboard the roads were. Logging trucks go up this road a lot.
Is the design of the rear differential to blame for washboard roads? Seems to me to be the case since the bumps are evenly spaced.
Cheers :smile:
I would be more likely to believe that suspension systems are to blame. Others may know more.
zedex,
I noticed this washboard effect once in northerrn Illinois where there are absolutely no hills. It occurs on roads that are basically dirt with just an oily tar coating, that is the surface is not very stable. It also occurs only at intersections (before the road crosses the other road). My theory was that it's caused by the constant breaking, which pushes forward on the road as cars come to a stop. The effect on other parts of the road where cars aren't accelerating as much or as often would be far less.
In the mountains just going up and down hills requires a lot of force being applied to roads, and with big trucks, even more force.
Anyway that's my guess.
I agree with Integral. A standard vehicle has 2 primary suspensions; front and rear. Load forces are placed via the wheels on roads, and a moving vehicle generally has asymmetric loading on suspension, usually(though not always) with the greater load on the rear. Compressible road surfaces are affected under these circumstances. "Washboarding" results.
Factors including vehicle speed, total gross vehicle weight, axil loading differentials, axil spacing, road composition and traffic throughput have influence.
A heavily traveled compressible road surface often has more tightly space "washboards" due to the collective effects noted above.
excellent. Makes sence. Thanks guys.
  • · Replies 24 ·
  • · Replies 26 ·
20K
  • · Replies 21 ·
