Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Quantum Physics
Reply
image Canonical variables Share It Thread Tools Search this Thread image
Old Jun21-07, 03:01 AM                  #1
ehrenfest
ehrenfest is Offline:
Canonical variables
Can someone give me a good definition of a canonical variable? I have seen it in the context of Lagrangians and Hamiltonians. I currently understand it as a "generalization" or an "abstraction" of a regular variable, but there has got to be a better definition.
Old Jun22-07, 01:11 AM       Last edited by smallphi; Jun22-07 at 01:20 AM..            #2
smallphi
smallphi is Offline:
First you define the system with a Lagrangian (function of generalized coordinates, their time derivatives and time). From that Lagrangian you form the Hamiltonian (function of generalized coordinates, momenta and time). Those generalized coordinates and momenta are canonical cause the Hamilton equations of motion look in the 'canonical way':
LaTeX Code:  \\frac{dq}{dt} = \\frac{\\partial H}{\\partial p}
LaTeX Code:  \\frac{dp}{dt} = - \\frac{\\partial H}{\\partial q}
Now later you may decide to change the generalized coordinates, momenta and even time to other coordinates: (q, p, t) -> (Q, P, T). A change of the variables in general changes the form of the differential equations of motion. The new variables are called canonical if then new equations of motion have the same 'canonical' form albeit with different effective Hamiltonian K:
LaTeX Code:  \\frac{dQ}{dT} = \\frac{\\partial K}{\\partial P}
LaTeX Code:  \\frac{dP}{dT} = - \\frac{\\partial K}{\\partial Q}
You can test if a coordinate transformation of (q, p, t) will be canonical by using Poisson brackets.
Old Jun22-07, 10:21 AM       Last edited by lightarrow; Jun22-07 at 11:31 AM..            #3
lightarrow
lightarrow is Offline:
First you have to find the generalized coordinates {LaTeX Code:  q_i } of the n degrees of freedom system as n parameters which identify univocally the system's state.
Once defined the n generalized coordinates {LaTeX Code:  q_i } i = 1,..n and the relative lagrangian LaTeX Code: L(q_i,\\dot {q_i},t) , then coniugated momentums are defined as
LaTeX Code: p_i = \\frac{\\partial L}{\\partial \\dot {q_i}}
The set of all {LaTeX Code:  q_i } and {LaTeX Code:  p_i } are the canonical variables. The Hamiltonian function is defined as:
LaTeX Code: H(q_i,p_i,t) = \\sum p_i {\\dot {q_i}}  -  L
Then canonical equations come from that.
image image
Reply
Thread Tools
Similar Threads for: Canonical variables
Thread Thread Starter Forum Replies Last Post
canonical princeton118 Classical Physics 0 Nov28-07 12:08 PM
Angular Variables and Tangential Variables needhelp2008 Introductory Physics 1 Nov24-07 01:11 AM
what does canonical mean? captain Quantum Physics 4 Aug7-07 06:51 AM
non-canonical versus canonical DNA segment sobored Biology 1 Dec14-05 04:04 AM
What does canonical mean? Galileo General Physics 11 Dec22-04 05:36 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
