What is the magnitude of the vector product?
The problem involves finding the vector product of two given vectors, \(\vec{A}\) and \(\vec{B}\), expressed in unit vectors, as well as determining the magnitude of that vector product. The vectors are defined as \(\vec{A} = 5.00\hat{i} + 2.00\hat{j}\) and \(\vec{B} = 3.00\hat{i} - 1.00\hat{j}\).
  • Participants discuss the calculation of the vector product using different methods, including the determinant rule and the sine formula. There is confusion regarding the signs of the components and the correctness of the original poster's answer compared to the book's answer.
The discussion is ongoing, with participants examining the calculations and questioning the accuracy of the vectors provided. Some guidance has been offered to double-check the components of the vectors, and there is recognition that both methods yielded the same magnitude, though there is uncertainty about the correctness of the original poster's answer versus the book's answer.
There is a potential issue with the stated components of vector \(\vec{B}\), as participants suggest that flipping the x and y components could align the original poster's answer with the book's answer. The original poster expresses confusion about the signs and the interpretation of their results.
Equilibrium
Find the vector product [tex]\vec{A} \times \vec{B}[/tex] (expressed in unit vectors ) of the two vectors given. What is the magnitude of the vector product?
[tex]\vec{A} = 5.00\hat{i} + 2.00\hat{j}[/tex]
[tex]\vec{B} = 3.00\hat{i} - 1.00\hat{j}[/tex]
[tex]\vec{A}\vec{B}\sin(\theta)[/tex]
using pythagorean theorem i found that the resultant of the two is
5.39 and 3.16
plus the total angle w/c is 40.2
using the formula mentioned above i found the answer as 11k and magnitude of 11.0
what i am confused is that it has a different answer from the back of my book w/c is -[tex]-17\hat{k},17.0[/tex]
who is wrong the book or me?
and pls show me why?
Your answer seems correct to me. As a double check, find the cross product by multiplying the components.
my answer is wrong
the unit vectors should be
using the determinant rule
z =AxBy - AyBy
z = 5(-1)-2(3)
z = -11
-11\hat{k}
and the magnitude is where u use ABsin(theta) =11.0
Why do you say your answer is wrong? (Note that both methods gave you the same answer.)
:confused:
how?
the components shud be positive??
now I am confused
I'm not sure what you are asking. In your first post, you showed how you arrived at your solution. (Yes, your sign was wrong, but all you needed was the magnitude.) I said it was correct and asked you to double-check using a different method. You did and got the same answer for the magnitude. So why do you think your answer is wrong?
i thought this has two questions
Finding vector product AXB expressed in unit vectors and magnitude
Are you sure that you have both vectors stated properly? For example, flipping the x and y components of B yields the answer in the book: [tex]\vec B = 1.00\hat i - 3.00\hat j[/tex]. This is an easy mistake to make -- either by you or by the authors.
Good eye, D H. I'll bet that's it.
so the book is wrong then...
One of you must be. For the problem as you described it here, your solution is correct. (Make sure you copied it correctly, as D H suggested.)
14K
