Low Carbon Steel Supplier: Find 1010, 1008, 1002
  • Thread starter Thread starter pilot
    Carbon Steel
The discussion centers around finding suppliers for low carbon steel grades, specifically 1010, 1008, and 1002, with a focus on specific dimensions and applications. Participants share their experiences and suggestions for sourcing these materials, including challenges faced in obtaining the desired sizes and types.
  • One participant seeks suppliers for low carbon steel grades 1010, 1008, and 1002, expressing difficulty in finding sources.
  • Another participant notes that the term "c.r. low carbon steel" may imply a misunderstanding regarding corrosion resistance, clarifying that these grades are not corrosion resistant.
  • A suggestion is made to check McMaster-Carr for smaller sizes and to consider local mills for larger or custom pieces, depending on the participant's location.
  • A participant specifies the exact dimensions needed for the steel, indicating that they have already tried several suppliers without success.
  • Another participant suggests that standard mill runs may not be available in the specified sizes and recommends contacting local machine shops for custom machining options.
  • One participant mentions that they are familiar with local machine shops but have not found the specific grades they need, indicating they can handle machining themselves.
  • Specific product listings from McMaster-Carr are provided, although one participant notes that the round stock is galvanized, which is unsuitable for their application.
  • A participant shares their use of 1018 steel for similar dimensions and applications, expressing a preference for 1010 or lower grades for their electromagnet projects.
  • Another participant relates their similar experience in sourcing materials for tattoo machine parts and expresses a willingness to share information if they find a supplier.
  • A question is raised about sourcing bulk suppliers for heat shrink tubing related to the discussed applications.
Participants do not reach a consensus on a specific supplier or solution. Multiple competing views and suggestions are presented, with ongoing uncertainty about the availability of the desired materials.
Participants express limitations in sourcing specific grades and dimensions, and there is a reliance on local suppliers and machine shops, which may vary in capability and inventory.
This discussion may be useful for individuals seeking low carbon steel for specific applications, particularly in fields such as electromagnet design, machining, and custom fabrication.
pilot
anyone know of a supplier of c.r low carbon steel ie. 1010, 1008, 1002 I can't find a supplier, any info would be appreciated, thanks
It depends on the size and shape.
When you say c.r. low carbon steel, are you thinking 1010, etc... are corrosion reisistant? That class of steel is definitely not corrosion resistant.
If you are looking for relatively small sizes and/or non-complex shapes, you can get some through McMaster-Carr (www.mcmaster.com).
If you are wanting some large or custom pieces, you'll need to find some place that reps for a mill that is relatively local to you unless you want to pay shipping. I know quite a few places around me, but I doubt that that would help you. What city are you in?
Some on line places you can start are:
http://www.onlinemetals.com/
http://www.metalexpress.net/
The corrosion is not an issue, I've tried all the sites you listed with no luck, I'am looking for 5/16" rod and 5/16"x3/8" rect. As well as 3/16"x3" rect. and 1/4"x3/4" rect. I live in Wilmington N.C I've tried local steel suppliers and they can't help me, and keep sending me around in circles. If the price is right shipping does not concern me.
I see why you're having issues. You won't find standard mill runs in those sizes. You'll need some machining if those are hard and fast dimensions you have to have. Can you give the overall lengths as well?
Here is another link page to some more metal retailers:
http://icrank.com/cgi-bin/pageman/pageout.cgi?path=/directory/rawmaterial.htm&t=1
If that is the case I would look around for some local machine shops. They could give you a quote for exactly what you need plus material costs.
I've dealt with a few local machine shops as well, seeing if they had access to the grades I'am looking for with no luck. The machining I do myself. I don't need specific parts machined. I just need the dimensions that I stated in any particular length. Usally I buy my other metals by the ft. In any case dimensions close would be adequate so I don't have a ton of work to do thanks.
All of these are from McMaster-Carr www.mcmaster.com
Ø.3125 roundstock x 6 ft: P/N 9120K63 ($4.47)
Ø.3125 roundstock x 3 ft: P/N 9120K12 ($7.64)
.375 x .375 x 3 ft: P/N 9143K153 ($11.00)
.1875 x 3 x 1 ft: P/N 8910K543 ($8.57)
.1875 x 3 x 1 ft: P/N 8910K544 ($19.71)
.1875 x 3 x 1 ft: P/N 8910K134 ($34.27)
.25x .75 x 6 ft: P/N 8910K139 ($13.31)
The round stock is the right grade, but galvanized which is no good for my application. 1018 is what I use for all my dimensions already. I would be happy w/ 5/16 rod & 5/16x3/8rect in 1010 or lower. I use this material for elctromagnets and armatures. Not solenoids, but a soild core electromagnet with an oscillating armature. Basically an old fashioned doorbell circuit. I appreciate the help very much, thanks.
Building tattoo machine parts? I have had the same problem finding these materials. If you have any luck please pass that information along and I will do the same.
Have you found a good bulk supplier for the heat shrink tubing? What size fits the finished coil?
15K
