Calculating DC Offset for 19 High Bits Followed by Low Bit
  • Thread starter Thread starter Chrispp
    Bit Bits Dc
The discussion focuses on calculating the DC offset for a sequence of 19 high bits followed by a low bit. The correct formula for determining the DC offset is derived as [(19 - 1) * (the amplitude)] / 20, which represents the average value of the waveform. Participants clarify that the DC offset relates to the symmetry of the waveform around zero, and if the low value is zero, the DC offset equals 50% of the high value. This understanding is crucial for accurate waveform analysis.
  • Understanding of digital signal processing concepts
  • Familiarity with DC offset and RMS value calculations
  • Knowledge of waveform symmetry and its implications
  • Basic proficiency in amplitude measurement techniques
  • Research the calculation of RMS values in various waveforms
  • Explore digital signal processing tools for waveform analysis
  • Study the effects of DC offset on signal integrity
  • Learn about the implications of waveform symmetry in electronics
Electrical engineers, signal processing specialists, and anyone involved in digital waveform analysis will benefit from this discussion.
Chrispp
If I have a string of 19 continuous bits 'high' followed by a bit 'low', how do I calculate the DC Offset if the pattern is repeated? Is it just [(19 - 1)*(the amplitude)]/(20)?
Thanks for the help.
Chris
Yes, that looks correct. You are just calculating the average value -- that would be the DC offset.
DC offset??
Don't you mean equivilent DC voltage value?
This would be the RMS value in a sine wave.
AFAIK DC offset has to do with symmetry of the waveform around 0.
It would be 50% of the high value if the low value is 0.
  • · Replies 18 ·
