Twin Paradox: Are Causes Relative?
  • Context: Graduate
  • Thread starter Thread starter enridp
    Relative
The discussion revolves around the twin paradox and the causes of time dilation, exploring the perspectives of two twins: one on Earth (A) and one traveling at high speed (B). Participants examine the implications of different frames of reference and how they relate to the perceived differences in aging between the twins.
  • Some participants propose that from A's viewpoint, B is younger due to time dilation during B's inertial travel, while B perceives A's aging as affected by acceleration and a pseudo-gravitational field.
  • Others argue that both perspectives are valid within their respective frames, suggesting that the causes of time dilation can be interpreted differently depending on the observer's frame of reference.
  • A participant notes that the concept of geodesics in general relativity can provide a coordinate-independent analysis of time dilation, which may help clarify the situation.
  • Some participants express difficulty in visualizing the causes of the clock differences and seek further clarification on the implications of the geodesic concept.
  • There is a discussion about the relationship between acceleration and gravitational fields, with some asserting that acceleration can be seen as a cause of time dilation from B's perspective, while others challenge this view.
  • A participant shares a visualization resource aimed at helping others understand the twin paradox and time dilation more intuitively.
Participants do not reach a consensus on the nature of the causes of time dilation, with multiple competing views remaining. Some agree that both perspectives can coexist, while others emphasize the differences in interpretation based on the observer's frame.
Participants acknowledge the complexity of the topic, noting that the discussion involves various assumptions about frames of reference, the nature of geodesics, and the interpretation of acceleration in relation to gravitational fields. There are also unresolved mathematical steps regarding the geodesics and their implications for time dilation.
enridp
Hello !
I'm having troubles with the causes of time dilation.
I will to appeal to the twin paradox because it is known for everybody.
A = Earth twin.
B = traveller twin.
We know B is younger than A when he returns.
Now, why? I mean... from the viewpoint of A, he is younger because his time was dilated during his inertial trip (we can neglect the effect of acceleration here). But from the viewpoint of B, A was under the effect of "time dilation" too, but during the acceleration, B sees a uniform pseudo-gravitational field fill the universe. And this field is the cause of the final difference between B and A's clocks.
We have 2 very different "causes" for the same effect. What is the correct?
bye !
B only measures a gravitational field if he decides he is moving inertially, so that whatever acceleration he feels must be due to such a field. Whether he makes this "mistake" or accurately accounts for the fact that he is accelerating is irrelevant, because both are equivalent under Einstein's equivalence principle, and both lead to the same conclusions about the elapsed time on A's clock. In other words, your question is like asking: what caused my hand to burn, the heat of the stove or the molecular motion of its atoms?
enridp said:
Hello !
A = Earth twin.
B = traveller twin.
bye !
They are both correct. Both analyses are described in terms that depend on a particular frame or coordinate system, and both describe how that coordinate system acts.
If you'd like an example of a coordinate independent analysis, that would go something like "the observer who follows a geodesic maximizes his proper time. (In GR or SR with a funky topology, one would have to be a bit more careful and say "extremizes his proper time", because it might be possible to draw two different geodesics between two events in space-time, in which case only one of the geodesics would be a true maximum).
Because this analysis is written in terms that don't depend on the coordinate system, some of the extraneous coordinate dependent details are "filtered out". This has the advantage of not having so many different possible explanations, but it's a bit more abstract and it takes some time to learn coordinate independent language and thinking.
It's not necessary to use a coordinate independent analysis, of course, but one then has to be able to deal with the multiplicity of possible "causes".
Another typical example of this is that one observer might describe a force on a charge as being due to an electric field, while a different observer might describe the same force as being due to a magnetic field.
thanks StatusX !
At really I think yes, I mean... we can say: my hand was burnt because the heat of the stove which produced the motion of its atoms. They are not "conflicting causes".
But I can't visualize the cause of the real difference between A and B's clocks.
How do you interpret that consequence? (I mean... is the consecuence of what?) :confused:
thanks !
PS: I've seen the pervect's answer:
If I understand it correctly, the larger geodesic has the longest proper time, it can be showed mathematically, but the conceptual interpretation is that we are traveling at constant "c" in 4D (space-time), the geodesic is the shorter path in the spatial dimensiones, therefore, we are "wasting" the rest of our 4-velocity in time. Is this correct?
But, from the viewpoint of B (traveller twin), he is seeing his path like a longer or shorter geodesic (with respect to his brother)?
Then, there is an interesting change of the question.
pervect: Can you explain it better? I think It fazed me.
How can we solve it? Or we just accept the relativity of the causes?
thanks again !
Try my visualization:
http://physics.syr.edu/courses/modules/LIGHTCONE/LightClock/VisualizingProperTime-TwinParadox-v=8-A.avi
as part of
http://physics.syr.edu/courses/modules/LIGHTCONE/LightClock/ .
In my opinion, it provides a pedagogically attractive mechanism for marking the ticks on a piecewise-inertial worldline.
("It's all done with mirrors [and light-rays and the principle of relativity].")
No, the motion of the atoms just is the heat, one doesn't cause the other. In the same way, the acceleration is the gravitational field and the electric field is the magnetic field. What's relative is not the cause, but the name we assign to it. The different names are just how people with different points of view describe the same physical object.
Hi StatusX !
I like your answer:
"the electric field is the magnetic field"
But I don't know if we can use it like:
"acceleration is the gravitational field":
From the Earth's viewpoint the acceleration (or gravitational field) is not the cause, actually, we can neglect its effects if the acceleration's time->0.
But from the traveller's viewpoint the acceleration is the cause, we can not neglect it.
I don't know if I'm explaining my doubt in the right way because my english is very poor, I hope you understand it anyway.
Thanks !
In the limit that the time of acceleration gets very short, the magnitude of accelaration, and thus the magnitude of the gravitational field, gets correspondingly large, in such a way that the combined effect on time dilation is the same. It's the analagous to the way we think of a perfect dipole as being the limit two very close, very charged particles of opposite signs. Even though the two charges are (in the limit) right on top of each other, the fact that we've made their charges so large means they don't cancel.
On the other hand, in the acceleration interpretation, what determines time dilation is not the acceleration but the velocity. Thus it is actually simpler to assume the acceleration is instantaneous, since then we only ever have to integrate constant velocity paths.
enridp said:
thanks StatusX !
Unfortunately, this is not quite right.
Let's assume that we have two events, A and B, and that B is located inside the light cone of A, so that someone starting at A can reach event B without exceeding the speed of light.
A geodesic is like a straight line. If we restrict ourselves to suitably simple examples in SR, there is only one geodesic (you might also see the phrase time-like geodesic used) between A and B.
Thus there isn't a "longer" or a "shorter" geodesic. There is only one, unique geodesic connecting the two events. This geodesic has the longest elapsed time of any possible path that can be traversed between events A and B.
The whole point of this very abstract approach is to able to talk about the situation without using "viewpoints".
As I said before, it's perfectly OK to use "viewpoints", but then you have to deal with the fact that different "viewpoints" use different language to describe the exact same phenomenon, which is what you were complaining about.
Yes, you are right StatusX, and I understand it. I know there's no paradox. What I don't know is how to interpret this result. From the Earth's viewpoint acceleration is not important, only the inertial paths are (we can neglect acceleration in our calculus). From the traveller's viewpoint acceleration is the principal cause. We can't neglect it. Acceleration feels like a gravitational field, and then (from the traveller's viewpoint) the Earth grow older for that reason, I mean, acceleration is the cause for the traveller twin, but is not for the "Earth twin".
I can't understand what is the cause then. I understand the effects, but the causes not, that's my problem :-(
Greets !
PS: robphy: very nice web ! and wonderfull animations, thanks!.
It would be nice if you put some animations from the traveller's viewpoint, to see what he sees when is accelerating...
Thanks!
Yes, version 2.0 or 3.0(?) will have that.
(A version of my VPython programs used making the diagrams allow the scene to viewed dynamically from an arbitrary frame. That is, while the animation runs, the user can freely boost into different frame to see the diagrams drawn from that frame. However, it used some non-standard programming techniques that are now broken in the current versions of Python and VPython. When I get back to it, I'll try to fix them up.)
In the diagram from an accelerating frame, one has to confront the nontrivial issue of what the events on that diagram represent (and how they are determined operationally). [This diagram cannot be nicely transformed into one for an inertial observer, without possibly tearing, overlapping, or excluding regions of the diagram... which is an indication that two observers are not symmetrical.]
Hi pervect !:
Maybe that's the problem, I can't visualize what your are saying...
If we can't put the "viewpoint" in our traveller twin, then how can we understand what he is seeing?
Are accelerated frames invalid? I mean... if we are analyzing events from an accelerated frame, our conclusions are invalid?
(maybe it's like the centrifugal force...)
From the traveller's viewpoint, is he following a geodesic?
I don't really know what you mean by something "causing the time difference." Time just travels at different rates for different observers, this needs to be taken as a basic fact in relativity. The best you can do is ask what's causing the clock of another observer to be currently ticking at a different rate than yours, and two ways you might try doing this are 1) by claiming he's moving, or 2) by claiming he's at a different location in a gravitational field.
If you go through this problem in a step by step way, and note what each twin observes of the other at each point, it will turn out that both twins will observe their counterparts to be aging slower at every point of the journey, except at the turning point, where the moving twin (the one who feels acceleration) sees his brother suddenly age at a tremendous rate, which he could attribute to him being higher up in a gravitational potential. The Earth twin doesn't experience such a process, so his brother will always appear younger to him.
I'm getting a bit burned out on this discussion, but if you'd like to read more of the approach I have been describing, try:
http://www.eftaylor.com/pub/chapter1.pdf
in the section on "the principle of maximal aging".
Here's a short quote:
The lesson of the Twin Paradox is that the natural motion of a free object
between two events in flat spacetime is the one for which the wristwatch
worn by the object has a maximum time reading between those two
events. Purists insist that we say not maximum reading but rather extremal
reading: either maximum or minimum. This book contains only examples
of maximum wristwatch time for natural motion. Still, let’s try to keep the
purists happy! Replace the two words maximum and minimum with the
single word extremal. The result is the Principle of Extremal Aging.
Sorry if this isn't getting through, I think I may have introduced some concepts that are too advanced for where you're at - and I also may not be doing a great job of writing. If it's the later that's the problem, I'd suggest reading the online artilce above, as Taylor writes much better than I do, at much greater length, and with some very helpful supporting diagrams.
Hi StatusX !
Yes, I know that, and that is what I'm asking at really.
The moving twin says the cause is the gravitational field, without this gravitational field his brother will be younger.
And the Earth twin says the acceleration has nothing to do here. His brother is younger because he was moving.
Then why cocks walk at different rates?
I always see that effect like an "illusion", I mean, if the traveller twin doesn't back, who is younger? both sees the other is younger. And it's OK to me, time is relative, but when the twin turn back, he is the younger ("absolutely").
Then, if during his 1st leg of the trip the time was an "illusion" (both sees the other is younger), and durint the home coming again, both sees the other is younger, when was the "real" change of the clocks?
Earth twin: during 1st and 2nd legs traveller's clock was running slowly.
Traveller twin: during 1st and 2nd legs Earth's clock was running slowsly but during acceleration Earth's clock was running very very fast.
I know all the maths works perfectly, but I think physics it's not only maths, maybe I'm wrong, but I need a cause for every effect, here the effect is the difference between the two clocks, and I can't find the cause of that effect.
I know RE is OK, and I know the paradox doesn't exists at all, but I can't find the cause of the final effect, that's my problem :-(
I hope you can help me to understand it.
bye !
PS: pervect: I will read the pdf, thanks !
The whole point of relativity is that there are no absolutes: one observer's interpretation is just as good as another's, even if they are completely different. And the math works out so that all concrete observations are the same.
When the twins are separated, before the first one turns, both will observe the other's clock (by the way, that l is important) running slowly, but it's meaningless to ask who's right, because there's no way to directly compare the clocks. To emphasize: the twin's observation of the other's clock running slow is as real as his observation of his own clock, it is not an illusion. The apparent contradiction is resolved not by claiming the measurements are somehow wrong, but by noticing that there's no way to compare the clocks, and so no way to expose a contradiction.
After one turns around and returns to his starting point, there are a few different interpretations of what happened, as I've explained a few times. But they are all underlied by the fact that one twin has traveled less proper time, according to the metric. The different interpretations are all derived from the metric, which is a tensor, and so independent of coordinate system (ie, frame of reference), and this is why the observations all come out the same.
I'm sorry, I don't think I can explain this any better. All I can say is you need to understand the different nature of the relativistic theory and the Newtonian theory. Specifically, the ambiguity of simultaneity in relativity is one thing I think you're not completely appreciating. It might help to look at this situation from the points of view of various other observers moving relative to both twins.
This type of thing isn't specific to relativity. The fact that there are "uniform gravitational fields" in non-inertial frames in flat spacetime is directly analogous to the fact that there are fictitious forces in non-inertial frames in classical mechanics. If I'm on the edge of a rapidly spinning wheel and I let go of a ball which flies off at a tangent, in an inertial frame this is just because objects move in straight lines when no forces are acting on them, but in a non-inertial frame where the wheel is at rest it's due to some combination of the "centrifugal force" and the "coriolis force". Would you say that this means "causes are relative" in classical mechanics too? It seems to me that this is basically an issue of semantics, it depends on what you mean by "cause".
Thanks again StatusX, and don't worry, I understand you, I'm really familiarized with relativity effects like simultaneity and time dilation and I know there's no possible to compare the clocks in two inertial frames. I know we can explain the final effect like a long and shorter way according to the Minkowski metric.
But it's really difficult to me say why. All the maths are OK, they work fantastic and in a really elegant manner. But if you ask to me why my phone is blue and my wall is white, I just answer: because they are made of different materials and atoms, and they reflect in a different way the light.
But I can't find the answer to the rhythm of the clocks. If the movement is not the cause, if the acceleration is not the cause, then, what is the cause?
JesseM:
I think you hit the nail on the head. I think there's no problem with relativity of the causes too... but I'm not sure.
Anyway in Newtoninan mechanics you can explain it by "fictious forces" or just because objects move in a straight line (geodesic in GR). That is, it's easy to find the "cause". But I can't see the cause to the rhytms of the clocks... is the longest length (in 4D=>spacetime) a cause? I see it like a method for computing the results, not like a cause, maybe it's only my problem, I don't know...
You certainly can compare two clocks in two inertial frames... it just that the result depends on who is making the measurement and what is the nature of that measurement.
I'm curious what "message" you got from the visualizations I linked to earlier.
It may be that my message wasn't clear enough. If so, I'd like to understand better what is unclear.
I really should just give up at this point, but I get obsessed with explaining things clearly. So I'll keep going.
At a certain point you need to take some facts as basic. You seem to be more picky about this in relativity than in the case of atoms reflecting light of different wavelengths because of different internal structure, which you seem to take as a sufficient explanation in itself, even though this question has puzzled scientists for thousands of years.
Here's a situation completely analagous to the twin paradox. Two people are in a field. They are pushing along wheels that measure distance. That is, the wheels are, say, 1 m in circumference, and every time they turn they click off a reading. Now one person travels in a straight line from one point of the field to another, while the other goes a more roundabout way between the two points. When they meet up, the first person will find that his wheel has turne fewer times than the second person's, even though they've traveled between the same two points. Does such a result need a cause, or can't we just say that the second person has traveled a further distance the the first?
It's a great analogy StatusX, I appreciate you just don't give up :)
I will think it in 4D to see if it works in my brain.
robphy:
I have seen your video, but I see it like the vision of the Earth frame, not the cause of the real difference in the clocks, I mean, if the twin doesn't back, the first part of the video is the same anyway, because it's the erath's vision of the time.
Do you understand the mathematics behind it as well as the concepts, once you do this becomes much easier. The relative vector mathematics?
I think that this is something you need to look at on both levels, and you need to get over your assumptions about the way things work before you do so. It is possible to understand this in terms of concepts, but it is far easier to understand it in terms of mathematics and concepts. I fear most people don't try and look further than just their stumbling blocks.
Although for me at least before I got to grips with the maths, I could visualise acceleration as the driving factor by visualising two relative conditions, some people can't, but try and see it in your minds eye as two separate vectors differ in their acceleration: time dilates by an effect of this.
Some of you guys won't resolve your problems without resolving your problems in maths it seems, I would suggest you do so. Not meant to be patronising, I fully understand how difficult the concepts are to grasp.
enridp,
One key message is that one-tick of a light clock is determined by the double-cone of light rays, emitted by an event for the first tick, then received at an event for the second tick, after a reflection on the mirrors of the light clock. This statement does not depend on which inertial frame is doing the viewing.
The shapes of the double-cones may differ [just as the orientation of a plane containing the reflection events may differ]... but the same mechanism of light-rays reflecting off the mirrors applies. All light rays are still oriented at 45-degrees, a feature of the speed of light postulate. In fact, the spacetime-volume enclosed by those light rays is the same for each piecewise-inertial worldline [assuming the use of identically constructed light clocks]... a Lorentz invariant: one tick of proper-time on a standard clock.
The analogue of the standardized light clock in StatusX's example is a standardized wheel to determine the distance, in units of wheel circumferences.
The difference in the clock readings between the meeting events is now simply a result of taking different routes in spacetime between two events, just as the difference in odometer readings in StatusX's example is a result of taking different routes in space between two points. Note that some turning off of a straight line was done by the "indirect traveller", but no distance was accumulated by the odometer, assuming an instantaneous turn. Likewise, some acceleration off an inertial worldline was done by the "indirect traveller", but no time was accumulated by the light clock, assuming an instantaneous turn.
In StatusX's example, to detemine elapsed distances along each path, you focus on the wheel circumferences elapsed along each path. (You could focus on what the other guy's odometer reads at a point on the other's guy's path perpendicular to your own path, then make a comparison... then, worry about what happens after the turn... but this all complicates the issue... right?)
In the spacetime example, to detemine elapsed times along each worldline, you should focus on the light-clock ticks elapsed along each worldline. (You could focus on what the other guy's clock reads at an event on the other's guy's worldline Minkowski-perpendicular [parallel to the plane of reflection events] to your own worldline, then make a comparison... then, worry about what happens after the turn... but that complicates the issue... right?)
  • · Replies 137 ·
11K
  • · Replies 42 ·
  • · Replies 43 ·
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 85 ·
  • · Replies 71 ·
