How can an ohmmeter determine if two points on a protoboard are connected?
  • Thread starter Thread starter vptran84
An ohmmeter determines if two points on a protoboard are connected by measuring the resistance between them. It utilizes an internal voltage source and a galvanometer to measure current flow. When two points are not connected, the ohmmeter indicates infinite resistance due to zero current. Conversely, if the points are connected, the device shows a finite resistance value, confirming connectivity.
  • Understanding of electrical resistance
  • Familiarity with ohmmeters and their operation
  • Basic knowledge of protoboard circuitry
  • Concept of current flow in electrical circuits
  • Research the operation principles of ohmmeters
  • Learn about measuring resistance in different circuit configurations
  • Explore protoboard layout techniques for effective circuit design
  • Study the relationship between voltage, current, and resistance (Ohm's Law)
Electronics enthusiasts, hobbyists working with protoboards, and students learning about electrical measurements will benefit from this discussion.
vptran84
how can an ohmmeter be used to determined if two points on a protoboard are connected?
thnks
thnks
By measuring the resistance between the points?
Just to extend on Integral's answer, an ohmmeter measures the resistance between the two points using an internal voltage source and a galvanometer, which measures current. If you measure the resistance between two points that are not connected, the current will be zero and the resistance will be "infinite". If the points are connected, however, there will be current and a finite resistance.
12K
  • · Replies 20 ·
33K
