Why Must the Expectation Value of H Be at Least the Lowest Energy Eigenvalue?
  • Thread starter Thread starter ehrenfest
    Eigenvalue Energy
The discussion revolves around the expectation value of the Hamiltonian operator H in quantum mechanics, specifically addressing why this value must be at least equal to the lowest energy eigenvalue E_0. The original poster presents a problem statement that involves normalizing a state vector |psi> and calculating the expectation value .
  • Participants explore the expansion of |psi> in the eigenbasis of H and discuss the implications of using different basis states. There are attempts to clarify the relationship between the expectation value and the eigenvalues of H, with some participants questioning the assumptions made about the Hamiltonian.
Several participants have provided insights into the mathematical formulation of the problem, discussing the orthonormality of eigenstates and the implications of the normalization condition. There is an ongoing exploration of the reasoning behind the expectation value being greater than or equal to E_0, with some participants expressing confidence in the validity of the statements made.
There is a mention of the assumption that the Hamiltonian may be simplified under certain conditions, and participants are considering the implications of this assumption on the overall problem. The discussion also reflects varying levels of familiarity with the notation and concepts involved.
ehrenfest
Shankar 163
Show that for any normalized |psi>, <psi|H|psi> is greater than or equal to E_0, where E_0 is the lowest energy eigenvalue. (Hint: Expand |psi> in the eigenbasis of H.)
I think the question assumes the V = 0, so H = P^2/2m. The eigenvalues for the equation P^2/2m|p> = E|p> are then p = +/- (2mE)^(1/2) and the eigenkets are of the form | p = + (2mE)^(1/2)> and | p = (2mE)^(1/2)> (or in energy terms the eigenvalues are of the form |E,->, |E,+> and the eigenkets are the same as the momentum ones. I'm not really sure how you can expand anything with these though...
No, this statement is valid for any Hamiltonian.
To spare your pencil, assume the system has only two basis states and develop <psi|H|psi>, you will see how obvious this result is.
(take the basis states as H-eigenvectors for simplicity, then imagine th consequence if you don't know these eigenvectors but would like to find the fundamental state, very useful statement indeed!)
This is how we expand [tex]\Psi[/tex] in terms of the eigenbasis of H :
Use the fact that the eigenvalues of H which is [tex]\{\Psi_0,\Psi_1,\Psi_2 ...\}}[/tex] forms the basis of a Hilbert space. Notice Hibert space is completed.
That means any vector [tex]\Psi[/tex] could be written as a linearly combinition of [tex]\Psi_0,\Psi_1,\Psi_2 ...[/tex]
i.e. [tex]\Psi = c_0\Psi_0+c_1\Psi_1+c_2\Psi_2+...[/tex].
The problem should be trivial from this point ( use the orthogonality of the eigenvector, although the eigenvectors in degenerate state are not orthogonal, they do not affect the result. )
Of course the end result is
<H> = p1 H1 + p2 H2 + ...
where pi is the probability of being in state i,
and 0<pi<1
and p1 + p2 + ... = 1
OK. So we use the time-independent version of the Schrödinger equation H * psi = E * psi.
So [tex]|\psi> = p0 * |H0> +p1 * |H1 > + ...= a0 * |E0> + a1 * | E1> + ...[/tex]
p (and my choice of a) are arbitrary letters, right? You did not use p for momentum did you lalbatros?
Now, [tex]<\psi| H | /psi> = (E0*a0 + E1*a1 + ...)</psi|/psi> = E0*a0 + E1*a1 + ...[/tex]
So the minimum of that expression would occur when a0 = 1 and ai = 0 for all i > 1.
Does that explanation work?
Your notation is confusing. I'll confuse the waters a little more by posting ugly, non-TeX. Which I prefer to garbled TeX. |psi>=sum(ci*|Ei>). ci are the amplitudes, |Ei> is the eigenstate corresponding to eigenvalue Ei. So <psi|H|psi>=sum(ci*conjugate(ci)*<Ei|H|Ei>)=sum(ci*conjugate(ci)*Ei*<Ei|Ei>).
Since we'll take |Ei> normalized <Ei|Ei>=1.
So <psi|H|psi>=sum(pi*Ei) where pi=ci*conjugate(ci). Since we'll also take |psi> normalized, sum(pi)=1.
So if sum(pi)=1, pi>=0, do you believe sum(pi*Ei)>=E0 where E0 is the smallest of the Ei's? Can you prove it?
I believe it.
sum(pi*Ei) >= sum(pi*E0) = sum(pi)*E0 = E0
How do you go from |psi>=sum(ci*|Ei>) to <psi|H|psi> = sum(ci*conjugate(ci)*<Ei|H|Ei>)?
Shouldn't it be something like <psi|H|psi> = sum(conjugate(ci)*<Ei|) H sum(ci*|Ei>) just by replacing |psi> with sum(ci*|Ei>) and < psi| with sum(conjugate(ci)*<Ei|)?
We've taken the |Ei> to be orthonormal, so <Ei|Ej>=delta(i,j) And H(ci*|Ei>)=ci*Ei*|Ei>. And your proof is perfect.
I see. Thanks.
You really do? You're not kidding, right?
  • · Replies 30 ·
  • · Replies 20 ·
