Related Rates - Water poured in a bowl
The discussion focuses on the mathematical modeling of water being poured into a bowl shaped as a cap cut from a sphere. The volume of the cap is expressed as V = (1/3)πh²(3a - h), and the rate of water being poured is given by dV/dt = πa³/24. The relationship between the depth of water x and time t is established as 24(dx/dt) = a³/(x(2a - x)). It is concluded that if the bowl starts empty, it will take exactly 5 seconds to fill up, derived through integration of the established rate equation.
  • Understanding of calculus, specifically integration and differentiation.
  • Familiarity with the geometric properties of spheres and caps.
  • Knowledge of volume formulas for three-dimensional shapes.
  • Ability to manipulate algebraic expressions and solve equations.
  • Study the derivation of volume formulas for spherical caps and their applications.
  • Learn about differential equations and their solutions in physical contexts.
  • Explore integration techniques, particularly for polynomial functions.
  • Investigate related rates problems in calculus for practical applications.
Students and professionals in mathematics, physics, and engineering who are interested in fluid dynamics, calculus applications, and geometric modeling.
danago
The volume of a cap, of depth h cm, cut from a sphere of radius a cm (a>h) is given by [tex]V = {\textstyle{1 \over 3}}\pi h^2 (3a - h)[/tex]
. A bowl is in the shape of a cap of depth a/2 cm cut from a spherical shell of radius a cm. Water is being poured into the bowl at a constant rate of [tex]\frac{{\pi a^3 }}{{24}}[/tex]
. Show that, when the depth of the water in the bowl is x cm, [tex]24\frac{{dx}}{{dt}} = \frac{{a^3 }}{{x(2a - x)}}[/tex]
. Hence show that, if the bowl is initially empty, it will take 5 seconds to fill up.
I managed to do the first part of it:
[tex] \begin{array}{c}<br /> V = {\textstyle{1 \over 3}}\pi x^2 (3a - x) \\ <br /> = \pi ax^2 - {\textstyle{1 \over 3}}\pi x^3 \\ <br /> \frac{{dV}}{{dt}} = 2\pi ax\frac{{dx}}{{dt}} - \pi x^2 \frac{{dx}}{{dt}} \\ <br /> = \frac{{dx}}{{dt}}(2\pi ax - \pi x^2 ) \\ <br /> \frac{{dx}}{{dt}} = \frac{{\frac{{dV}}{{dt}}}}{{(2\pi ax - \pi x^2 )}} \\ <br /> = \frac{{\pi a^3 }}{{24(2\pi ax - \pi x^2 )}} \\ <br /> = \frac{{a^3 }}{{24(2ax - x^2 )}} \\ <br /> 24\frac{{dx}}{{dt}} = \frac{{a^3 }}{{x(2a - x)}} \\ <br /> \end{array}[/tex]
But with the second part, it says "Hence, show that if the bowl...". What I am not getting is how to use the part above to show that it takes 5 seconds?
I managed to do it like this: (i think it is correct, anyway)
The maximum volume the bowl can hold is given by
[tex] \begin{array}{c}<br /> <br /> V = {\textstyle{1 \over 3}}\pi h^2 (3a - h) \\ <br /> = {\textstyle{1 \over 3}}\pi ({\textstyle{a \over 2}})^2 (3a - {\textstyle{a \over 2}}) \\ <br /> = \frac{{\pi a^2 (3a - 0.5a)}}{{12}} \\ <br /> = \frac{{5\pi a^3 }}{{24}} \\ [/tex]
The bowl is full at time T
[tex] \begin{array}{l}<br /> \int_0^T {\frac{{\pi a^3 }}{{24}}} dt = \frac{{5\pi a^3 }}{{24}} \\ <br /> \left[ {\frac{{\pi a^3 }}{{24}}t} \right]_0^T = \frac{{5\pi a^3 }}{{24}} \\ <br /> \frac{{\pi a^3 }}{{24}}T = \frac{{5\pi a^3 }}{{24}} \\ <br /> T = 5 \\ <br /> \end{array}[/tex]
But i don't know how to do it using the fact that [tex]24\frac{{dx}}{{dt}} = \frac{{a^3 }}{{x(2a - x)}}[/tex].
Any help greatly appreciated.
Thanks,
Dan.
after some simple manipulation, this will become:
[tex]\frac{24x(2a-x)}{a^3} dx = dt[/tex]
then integrate over both size...
[tex]\int_0^{a/2}\frac{24x(2a-x)}{a^3} dx = \int_0^Tdt[/tex]
solve for T and you will get the desired answer...
Ah ok, thanks for that :smile:
  • · Replies 105 ·
13K
