Solve Projectile Fragments Problem with Hint
  • Thread starter Thread starter heartofaragorn
    Projectile
The problem involves a fireworks rocket launched at a specific speed and angle, which explodes into two fragments at the peak of its trajectory. The discussion centers around the dynamics of the fragments post-explosion, particularly focusing on their motion and energy conversion during the event.
  • Participants discuss the application of conservation of linear momentum and its implications for the motion of the fragments. Questions arise regarding the relevant equations and concepts necessary to analyze the problem effectively.
Some participants have provided hints regarding the use of conservation laws to approach the problem. There is an acknowledgment of the need for further exploration of the relevant formulas and concepts, with no explicit consensus reached on a complete method.
The original poster expresses difficulty in finding similar problems in their resources, indicating a potential gap in understanding the application of the concepts involved. The discussion reflects a need for clarification on the principles of momentum and energy in the context of projectile motion and explosions.
heartofaragorn
A fireworks rocket is fired with a speed of 80 m/s at an angle of 60 degrees above the horizontal. At the highest point of its trajectory, the projectile explodes into two fragments, one three times heavier than the other. The two fragments hit the ground at the same time, and the heavier fragment is hurled backwards so it lands at the same point from which it was launched.
How far away from the launch point does the lighter fragment land? How much energy was converted from chemical energy during the explosion into kinetic energy?
Not a clue
Looked through my professor's lecture notes and example problems, looked through the applicable chapters in the book...and I can't seem to find any problem that resembles this one. I'm completely and utterly stumped. If someone could just give me a hint as to the appropriate equations, I think I can figure it out...but I just have no clue.
You're supposed to use the conservation of linear momentum. At the highest point, the particle is in horizontal equilibrium, hence, m1(v1)=-m2(v2). Since m1=3m2, v2=3v1 (in opposite direction).
Using this, you should be able to solve for v1, and hence v2. From there you can find the kinetic energy.
Ohhhh. I don't think I've ever seen those formulas. Thank you!
Then you better look up conservation of linear momentum.
9K
10K
