Angular Frequency of Uniform Disk | Calculation & Solution
The discussion focuses on calculating the angular frequency (ω) of a uniform disk with a radius of 1.4m and mass of 2.6kg, suspended from a pivot located 0.35m above its center of mass. The relevant equation for angular frequency is ω = 2πf = √(k/m). To accurately determine ω, it is essential to compute the moment of inertia using the parallel axis theorem, as this is a physical pendulum problem.
  • Understanding of angular frequency and its relation to frequency and spring constant.
  • Knowledge of moment of inertia and its calculation methods.
  • Familiarity with the parallel axis theorem for shifting the axis of rotation.
  • Basic principles of physical pendulums and oscillatory motion.
  • Study the parallel axis theorem in detail to apply it to various shapes.
  • Learn how to calculate the moment of inertia for different geometries, including disks and cylinders.
  • Explore the concepts of physical pendulums and their oscillatory behavior.
  • Investigate the derivation of angular frequency formulas for various physical systems.
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to enhance their understanding of physical pendulums and angular frequency calculations.
Momentum09
A uniform disk of radius 1.4m and mass 2.6kg is suspended from a pivot 0.35m above its center of mass. Find the angular frequency w for small oscillations.
w = 2 x pi x f = sqrt (k/m)
Is this the equation I would use to solve this problem? Or does moment of inertia have to be considered also?
This is a physical pendulum. (Look it up!) You'll need to compute the rotational inertia about the pivot point.
Use the parallel axis theorem to find the moment of inertia of the disk about the pivot point.
