How to Find Particle Acceleration Using Conservation of Energy?
The discussion revolves around using conservation of energy to determine the acceleration of two identical particles in an isolated system. Participants explore the mathematical relationships involved, particularly focusing on the energy function and its derivatives, while seeking hints and clarifications on the correct approach to find the accelerations in terms of particle positions.
  • Homework-related
  • Ron presents the energy function for the system and seeks assistance in applying conservation of energy to find particle accelerations.
  • Some participants suggest that the derivative of the energy function with respect to time is zero, indicating energy conservation.
  • Ron expresses uncertainty about the mathematical steps, particularly regarding the time derivative of the energy function and the relationship between acceleration and velocity.
  • There is a discussion about the time dependence of the positions x1 and x2, with a participant questioning why their time derivative was considered zero.
  • Another participant suggests using the conservation of momentum in conjunction with energy conservation to relate the accelerations of the particles.
  • Ron acknowledges the feedback and indicates progress towards finding a solution.
Participants generally agree on the conservation of energy principle but express differing views on the mathematical treatment of the energy function and the implications for finding accelerations. The discussion remains unresolved regarding the exact method to derive the accelerations.
Participants note limitations in their mathematical approaches, particularly concerning the treatment of vector and scalar quantities, and the dependence of the energy function on time-varying positions.
Ron_Gis
Help
An isolated system of two identical particles, each of mass m, is described by an energy function
E = ½ m |v1|^2 + ½ m |v2|^2 + ½ k |x1 – x2|^2
How can I use conservation of energy to find the acceleration of each particle in terms of the position of the particle? I would be thankful if someone could give me a hint ?
Ron
Well, the derivative of E with respect to time is zero, so...
Hello krab,
thank you for your help. Your approch to the problem is correct. If the total energy is conserved, the first derivative with respect to time of the given equation should be zero. I have some problems with the maths. Nevertheless, I think that the first derivative is given by
m a1 dot v1 + m a2 dot v2 + 0 where a1 = dv1/dt and a2 = dv2/dt
but I am not sure about this. Furthermore, it is not possible to divide a scalar through a vector, even if the solution is correct. I am too stupid to find the correct expression for the accelerations a1 and a2. I would be thankful if you could help me again.
Ron
The first part is correct, but x1 and x2 change with time, so why did you get that the time derivative of ½ k |x1 ? x2|^2 is zero?
Hello krab,
you are right again. The first derivative is given by
m a1 dot v1 + m a2 dot v2 + k (x1 – x2) dot (v1 – v2)
and this expression is equal to zero.
Nevertheless, the dot product is a scalar and I have to find an expression for the accelerations, which are vectors. I think that this is not possible, simply by rearranging this equation. Would you be kind enough to give me another hint.
Regards Ron
m a1 dot v1 + m a2 dot v2 + k (x1 ? x2) dot (v1 ? v2)
Regards Ron
You are right. You cannot get it from just this equation. Are you allowed to use the fact that in this isolated system, total momentum is conserved? If so then v1+v2=constant, so a1=-a2 and the result follows.
Alternatively, go back to the beginning and use a "virtual displacement". Pretend that you move say particle 1 by a vector dx1. Use the energy equation to calculate the difference in energy this displaced system would have. From the definition of work, you know that this energy difference is F1 dot dx1.
Hello krab,
I think that I have found the correct solution. Thank you for your help.
Regards Ron
