Double-slit experiment question
The discussion revolves around the double-slit interference experiment, specifically focusing on determining the position of the first maximum given certain parameters such as wavelength, slit separation, and distance to the screen.
  • Participants discuss the use of Young's formula and the need to convert units. Questions arise about the definition of the first maximum and whether it refers to the central maximum or the first non-central maximum. There is also inquiry about the units for the position being sought.
Participants are actively engaging with the problem, clarifying definitions and exploring the physical meaning behind the y-displacement. Some guidance has been offered regarding unit conversion and the interpretation of maxima in the context of the experiment.
There is mention of a calculator being used, indicating that participants are working through numerical values, but the exact method for calculating the position remains under discussion. The problem's requirements regarding units and definitions are still being clarified.
jairusgarcia
The question goes like this,
From the 2-slit interference experiment, determine the position of the 1st maximum if lambda=400nm, d=1mm and D=10cm.
I've been reading through the experiment through external sites and none had given an example near the question. The question is, should i use Young's formula? What should i do first?
Thanks! ^_^
Draw a diagram - it's just trig.
Put all the dimensions in the same units.
mgb_phys said:
it's just trig.
how? i mean, draw a triangle and input the measurements? when the problem says find the maximum, is that the central maximum where n=0?
Since the central maximum is always in the center, that wouldn't be much of a challenge, would it? The first maximum means the first non-central maximum: where m = 1 (or n = 1, depending on your notation) in the Young's double slit formula. (Read this: Double Slit Interference)
ok. since there was a calculator there, i just inputted the values. back to the main question: the question asks the position. is the position in terms of what units? the angle and the y-displacement?
I assume that they want distance from the central maximum, which is the y-displacement.
ok thanks. last question. what is the physical explanation for the y-displacement? (sorry for this question. I am just confused)
In simple terms it's the point on the screen where the difference in distance from each slit is 1 wavelength.
Here the two rays of light are in phase - the high points of the waves coincide - they add to give a maximum (bright point).
Where the difference is half a wavelength, the maxmum of one aligns with the minimum of another and they combine to give a minima (dark point)
thanks for all the help!
