Monotonic bounded sequence theorem
The Monotonic Bounded Sequence Theorem asserts that a sequence that is both monotonic and bounded converges. Proving that a sequence is bounded can vary significantly based on the specific sequence in question. To establish boundedness, one can hypothesize an upper bound and validate its correctness, often employing mathematical induction. A rigorous approach involves defining the properties of bounded and monotonic sequences and utilizing the supremum axiom to support the proof.
  • Understanding of monotonic sequences
  • Familiarity with bounded sequences
  • Knowledge of mathematical induction
  • Comprehension of the supremum axiom
  • Study the properties of monotonic sequences in detail
  • Explore methods for proving boundedness in sequences
  • Learn about mathematical induction techniques
  • Investigate the supremum axiom and its applications in analysis
Mathematicians, students of real analysis, and anyone interested in understanding convergence in sequences will benefit from this discussion.
pakmingki
So the theorem states if a sequence is monotonic and bounded, it converges.
WEll, it's easy enough to prove is a sequence is monotonic, but how would one go about proving that a sequence is bounded?
?? Are you under the impression that there is ONE way to prove something? How to prove a sequence is bounded depends a lot upon the sequence! For one thing, how do you know it is bounded? Does it have an upper bound or a lower bound? If you feel sure that a sequence has an upper bound, can you guess an upper bound and then try to prove that is correct. Often with sequences, the best way to prove anything is by induction-show that if an< b then an+1[/b]< b. Of course, how you would do that would depend on how the sequence is defined.
If you're trying to prove the theorem in general, you simply have to write down what it means for a sequence to be bounded and monotonic, and use the supremum axiom, and poke into the definition of the supremum.
  • · Replies 18 ·
