Calculating Sun's Surface Temperature using Wien's Law
  • Thread starter Thread starter PhysiSmo
    Temperature
The discussion revolves around calculating the surface temperature of the sun using Wien's Law, given the maximum wavelength of solar radiation. Participants are exploring the relationship between wavelength and temperature in the context of black body radiation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss different formulations of Wien's Law, with some questioning the constants used in the original poster's equation. There is an exploration of the relationship between wavelength, frequency, and temperature, along with attempts to reconcile differing values for constants.
Some participants have provided alternative formulations and values, suggesting that the original poster may need to reconsider their approach. There is an ongoing examination of the equations and constants involved, with no clear consensus reached yet.
Participants note that the expected temperature range for the sun's surface is generally between 5500-6000 Kelvin, indicating variability in accepted values across different texts. The original poster's equation appears to differ from more commonly used forms of Wien's Law.
PhysiSmo
Given that the spectrum of solar radiation is that of a black body, and that the maximum wavelength is about 4800x10^(-10)m, calculate the temperature of the surface of the sun
[tex]\omega_{max}=\frac{2.82144 \cdot k_B}{\hbar}T[/tex] (Wien's Law)
[tex]f=\frac{c}{\lambda_{max}}[/tex]
[tex]\omega=2\pi f[/tex]
I'm getting a wrong result, knowing that the correct answer is about 5.500K. Thanx in advance!
I can't recall seeing Wien's law written in those terms before. Granted it was a while since I did anything on black body radiation. If you try [itex]\lambda_{max} T = 2.898x10^{-3}[/itex] one should obtain an answer of about 6000 Kelvin. One should know that the surface sun temperature has a range of values depending on what text you're using generally 5500-6000 degrees C. So anything in this range is normally ok.
I agree with Kurdt. See - http://hyperphysics.phy-astr.gsu.edu/hbase/wien.html
Certainly the value of 2.812144 differs from 2.898 x 10-3 m-K.
I recommend re-writing the Wien displacement law in terms of wavelength.
For T=5500 K, one should obtain a peak wavelength of ~526.9 nm with the formula given by Kurdt.
But my equation also contains the hbar and KΒ, and also expresses the ω(max), not the λmax with respect to T. So, the constants can't be equal, can they?
Anyway, the form with λmax is quite easier to work with. Thanx a lot!
But one wrote
[tex]f=\frac{c}{\lambda_{max}}[/tex] and
So one has a relationship for angular frequency and frequency and wavelength. Wien's displacement law is normaly written in wavelength, but it could also be written in frequency.
Also don't forget [itex]\hbar\,=\,h/2\pi[/itex] and E = h[itex]\nu[/itex], and Boltzmann's constant figures in the relationship between kinetic energy of gas molecules and temperature -
http://hyperphysics.phy-astr.gsu.edu/hbase/kinetic/kintem.html
and it's found in the Planck radiation formula
http://hyperphysics.phy-astr.gsu.edu/hbase/mod6.html#c3
  • · Replies 20 ·
