Solve Thermodynamics Question on Electric Wire with Plastic Cover
  • Thread starter Thread starter nickbone59
    Thermodynamics
The discussion revolves around a thermodynamics problem involving a high conductivity electric wire wrapped in a plastic cover. Participants are attempting to calculate the temperature at the interface of the wire and the plastic cover under steady-state conditions, as well as addressing the behavior of heat loss with varying insulation thickness. The scope includes theoretical calculations and conceptual clarifications related to heat transfer and electrical resistance.
  • Homework-related
  • One participant presents a calculation for the surface temperature of the wire, yielding a value of approximately 30.94°C, but expresses uncertainty about the correctness of this value.
  • Another participant discusses the power loss in the wire, suggesting that the heat generated can be calculated and that the surface area of the wire is relevant for determining heat loss from the outer cover.
  • There is a question about the relationship between insulation thickness and temperature, with one participant asking how to calculate the temperature difference through the insulator based on known parameters.
  • A participant mentions that the conductivity of the insulator indicates that a specific power transfer results in a temperature difference, emphasizing the balance of power into the wire and heat flow through the insulation.
  • One participant expresses confusion regarding the role of the surface convective heat transfer coefficient in the calculations, indicating a lack of clarity in the discussion.
Participants do not appear to reach a consensus on the calculations or the implications of insulation thickness on temperature and heat loss. There are multiple competing views and ongoing questions about the correct approach to the problem.
Some participants express uncertainty about the calculations and the relationships between variables, such as the role of the surface convective heat transfer coefficient and the effects of insulation thickness on heat loss and resistance. There are unresolved mathematical steps and assumptions that may affect the outcomes.
This discussion may be useful for students or individuals interested in thermodynamics, heat transfer, and electrical engineering concepts, particularly those working on similar homework problems or theoretical applications.
nickbone59
Hey, have been working on this question for about 2 weeks now and can't crack it, I found a formula on the net which gives me a value of just over 30C, i am not confident i have the correct value though. It just seems too low. I anyone could point me in the right direction with this it would be greatly appreciated.
Q1)
A high conductivity electric wire, diameter 3 mm and length 10m, is tightly wrapped with a plastic cover of thickness 1mm and thermal conductivity 0.15W/(mK). Electrical measurements indicate that as a current of 10A passes through the wire, there is a voltage drop 6V along the wire. The insulated wire is exposed to ambient conditions at a temperature of 30C with a surface convective heat transfer coefficient of 12W/(m^2K).
Neglecting any temperature variation across the wire cross-section,
i)calculate the temperature at the interface of the wire and the plastic cover under steady state operation.
ii)measurements indicate that the rate of heat loss from the wire increases rather than decreases as the insulation thickness increases. an the measurements be correct. Explain.
Heat generation in a resistive wire
Per unit volume : I^2R/Pi r0^2 L
= 100x0.442/pi x1.5^(2)x10^-3 x 10
=44.2/70.685x10^-6
=625446.7909
Surface Temperature:
To = T infinity + (g ro^2)/4k
= 303 + 62544.7909 x ((3x10^-3)^2/4x0.15)
= 303.938k
= 30.94c
Power loss in the wire is P = IV = 60w/10m = 6W/m, this is the heat into the insulator. You can work out the surface area of 1m of wire, and so the heat loss from the outer cover.
The temperature of the outer and the conductivity of the insulator is known - so you know the temperature difference through the insulator.
Part 2 - what happens to the temperature of anything as the insulation is increased? What happens to the resistance of a wire when the temperature increases? What does changing the resistance of the wire do to the power?
thank you
thanks that's a great help, hopefully i can suss it out now, thanks again.
actually i am still a bit unsure on how i calculate the temperature difference through the insulator from the temperature of the outer and the conductivity.
The conductivity of the insulator is 0.15W/(mK) with a thickness of 1mm.
So for every 150W ( ie 0.15/0.001) of power transferred through the insulation will give a temperature difference of 1K. In the stable state the power into the wire must equal the heat flow through the insulation.
i still don't understand? what your saying just doesn't make sense? Does the surface convective heat transfer coefficient not come into it?
