Creating PDF Files from Other Formats
  • Thread starter Thread starter quantumdude
    files Pdf
The discussion focuses on methods for creating PDF files from HTML or DOC formats, exploring various software solutions and techniques applicable across different operating systems. Participants share personal experiences and recommendations regarding tools and processes for PDF conversion.
  • Some participants suggest using Adobe Distiller as a printer driver for converting documents to PDF.
  • OpenOffice Writer is mentioned as a tool that includes a built-in PDF converter, particularly noted for its Unix/Linux version.
  • A free solution involving Ghostscript is shared, which requires installation but is accessible for users.
  • PDF 995 is highlighted as a reliable program for converting HTML documents, though one participant notes issues with PostScript files.
  • There is a query about the availability of programs that can convert PDF files back to Microsoft Word or other formats, with one participant expressing skepticism about the feasibility of such conversions.
  • Another participant suggests a manual method of copying and pasting content from PDF to Word, acknowledging the challenges with graphics.
  • A recommendation for PDFCreator, an open-source program that acts as a print driver, is provided.
  • One participant shares a detailed method involving Ghostscript and MikTeX for creating PDFs from .tex files, while also noting potential issues with printability on Unix/Linux systems.
Participants present multiple competing views on the best methods for PDF conversion, with no consensus reached on a single preferred solution. Some methods are endorsed while others are questioned or critiqued.
There are mentions of specific software dependencies and potential limitations regarding the compatibility of PDFs created from DOC/HTML files on different operating systems, particularly Unix/Linux.
quantumdude
Staff Emeritus
What is the easiest way to make PDF's from HTML or DOC files?
Computer science news on Phys.org
Use Adobe Distiller as a printer driver, and print them from IE or Word.
- Warren
OpenOfficeWriter (unix/linux version; I don't know about the windows version) includes a PDF converter. Select it as you would any printer on the print menu & it prints your document to a PDF file.
Here's a free solution for Windows I just accidentally came across:
http://home.hccnet.nl/s.vd.palen/index.html
It requires Ghostscript, but you probably have that already. (If not, it's free too.)
FYI, I wound up going with PDF 995. It works like a charm converting HTML documents, but it is having trouble swallowing a PS file that I have. I'll try the ones you suggested.
But is a program that can convert from PDF to Microsoft Word or other formats available yet?
recon,
Such a thing won't ever happen. It is not possible, except in rare cases.
- Warren
recon
Why don't you try Ctrl+A,copy ,paste in word(will take some time)
Unfortunately For graphic,you have to manually select one by one
Methinks,
There are lots of ways to do that, I personally usually do the same as what your question made especially when I run Windows: dirrectly create a pdf file from a doc file.
You have to download winteng which is available on the internet (Acrobat.com (?)). You also need to have Ghostscript, GhostView already installed, these two guys are also for free.
After you create your doc file and would like to make a change into pdf one, you print it to file first with a .prn extension and then open this .prn file under GhostView by which you are able to change it into a pdf format.
Another way I also use is via Miktex (?), I code my file in notepad or in some editor, and save it with .tex extension and just change this .tex file into dvi and then pdf, it is just in same way as what I or You usually do under Linux.
As a note, a pdf file created by directly changing from doc/html mightnot be printable under unix, linux system. I guess it is because of the way it was formated. Real Reasons ? I...don't...know...
I don't bother to look for them either because there are lots of ways to create a pdf file. But if anyone could post a reason for such a strange behavior of OSes, I would really love to seriously take it as nice future reference...:niceteeth:
