Finding the moment of inertia for a hollow cylinder
The moment of inertia for a hollow cylinder with a closed bottom can be calculated by summing the moments of inertia of both the cylinder and the disk at the bottom. The integral formula I = ∫ r² dm is essential for this calculation. To find the mass of each part, one can compare their relative areas, given that the thickness is uniform. The surface area of the cylinder is L x 2πr, while the area of the bottom is πr².
  • Understanding of moment of inertia concepts
  • Familiarity with integral calculus
  • Knowledge of geometric properties of cylinders
  • Basic principles of mass distribution
  • Study the derivation of the moment of inertia for various shapes
  • Learn about uniform mass distribution in solid objects
  • Explore applications of integral calculus in physics
  • Investigate the properties of hollow cylinders in engineering contexts
Physics students, mechanical engineers, and anyone involved in structural analysis or materials science will benefit from this discussion.
Antares
I need help finding the moment of inertia for a hollow cylinder with a closed bottom (like a glass of water). My strategy is to add the moments of inertia of the cylinder and the disk but I only have the total mass of the whole object. Is there a way to find the mass of each part or is there another approach to this problem?
Just sum the mass as an integral as follows.
[tex]I=\int r^2 dm[/tex]
If the thickness is uniform then you can find the masses of the cylinder and bottom by comparing their relative areas. The surface area of the cylinder is Lx2πr; the area of the bottom is πr2.
  • · Replies 40 ·
15K
