| Thread Closed |
pendulum swing --basic trig problems |
Share Thread | Thread Tools |
| Aug9-07, 02:55 AM | #1 |
lets say you have a pendulum swinging. the length of string is 1m it swings to the right so that the angle is 45deg. i want to find difference in height from when it is at rest to its new position at 45deg. How do i do this, trigonomically speaking i mean? i mean, where is the right triangle??? 2. Relevant equations not exactly a homework prob, but related to everything in homework 3. The attempt at a solution 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution i think i forgot sum basic trig, cause i cant figure out where the right angle triangle is to get my lengths from/???? |
| Aug9-07, 03:04 AM | #2 |
Recognitions:
The string of the pendulum is the hypoteneuse. Draw a vertical line through the top of the pendulum (like when the pendulum is at rest)... now draw a horizontal line from the swinging end of the pendulum to this vertical line. do you see the right triangle now?
| Aug9-07, 03:19 AM | #3 |
but if i do that, then vertical line is no longer 1m??
| Aug9-07, 03:19 AM | #4 |
because when it swings it is higher than it was at rest
| Aug9-07, 03:21 AM | #5 |
book says to go something like L-Lcos45 = L(1-cos45)
i dont undetsand why they say that, because when i apply basic trig (cos45 = adj/hyp) i get a totally differnt number than book ?? |
| Aug9-07, 03:21 AM | #6 |
Recognitions:
| Aug9-07, 03:22 AM | #7 |
so even though the right triangle cuts off the hypotenuse, i should still use hyp as 1m
| Aug9-07, 03:23 AM | #8 |
Recognitions:
| Aug9-07, 03:26 AM | #9 |
pleae allow the dumb question
--what is Lcos45 derive from??? i cant match it up to SOHCAHTOA? |
| Aug9-07, 03:28 AM | #10 |
Recognitions:
| Aug9-07, 03:29 AM | #11 |
Recognitions:
Ithink that you are still drawing the position of the string when it is at zero degree and this creates confusion. It might be better to draw on a separate figure, next to the first one, the position of the string when the object is at the lowets position. It should be clear that the difference of height is L - L cos 45. |
| Aug9-07, 03:30 AM | #12 |
Recognitions:
adj/hypoteneuse = cos 45 adj/L = cos 45 adj = Lcos 45 |
| Aug9-07, 04:40 AM | #13 |
thanks you
understand now |
| Thread Closed |
| Thread Tools | |
Similar Threads for: pendulum swing --basic trig problems
| Basic Collision/Pendulum Problem | Introductory Physics Homework | 7 | ||
| Trouble modeling runner’s swing-leg as double compound pendulum. | Classical Physics | 0 | ||
| What affects the swing of a pendulum w/ and w/o air resistance | Introductory Physics Homework | 1 | ||
| Very Basic Pendulum problem | Introductory Physics Homework | 4 | ||
| help with pendulum swing | General Physics | 2 | ||
