Definite Integration: 9_0 c/x^3 dx = (3/8)c
  • Thread starter Thread starter cd246
    Integration
The discussion revolves around the definite integral of the function c/x^3 from 0 to 9, with participants initially suggesting different interpretations of the problem statement and bounds. The subject area is calculus, specifically focusing on integration techniques and evaluation of definite integrals.
  • Participants discuss the setup of the integral, questioning the bounds and the expression used. There is an exploration of the evaluation process and whether the placement of x^3 affects the outcome. Some participants express uncertainty about their calculations and seek clarification on the correct interpretation of the integral.
The discussion is active, with participants clarifying the bounds of the integral and confirming their interpretations. Some guidance is provided regarding the expression of the integrand, but there is no explicit consensus on the correct evaluation method or outcome.
There is a noted confusion regarding the bounds of the integral, initially stated as 9_0 but later corrected to 2_1. This change appears to influence the evaluation results discussed by participants.
cd246
integration 9_0 c/x^3 dx. the answer is (3/8)c.
just distrib. then plug in the #'s
=cx^-3
= (cx^-2)/-2=c/-2x^2
I know it has something to do with distribution.
I assume your problem statement is supposed to represent this(please confirm):
[tex]\int^9_0 \frac{c}{x^3}dx[/tex]
If this is the case, I agree with your answer. When I evaluate the integral at the bounds I do not get the answer you stated. I get -c/162 as an answer. Are you sure that is correct?
My apologies, it is 2_1 not 9_0
Ahh if that is the case, then I do get (3/8)c as the answer. Were the bounds your problem, or is there something else?
that was pretty much it. did u put x^3 on top? or did you left the x^3 on the bottom? Because i believe that was my problem on this one.
I think it is good practice to write any fraction of c/x^n as cx^-n. I think it makes many problems look less complicated. So, yes, if this is what you mean, I did "put the x^3 on top."
ok i got it now. thanx
Your Welcome!
  • · Replies 105 ·
13K
  • · Replies 54 ·
19K
