Calculate NaHCO3 Molar Mass & Equilibrium Constants
  • Thread starter Thread starter gtfish
    Mass
The discussion focuses on calculating the molar mass of sodium bicarbonate (NaHCO3) and determining equilibrium constants for the reaction 2NaHCO3(s) <--> Na2CO3(s) + H2O(g) + CO2(g). Given a sample of 100 grams of NaHCO3 in a 5 L container at 160 degrees Celsius and a total pressure of 7.76 atmospheres, participants calculated the number of moles of H2O at equilibrium using the ideal gas law (PV=nRT) and derived the equilibrium expression for Kp. The molar mass of NaHCO3 is confirmed as 84 g, and the calculations involve determining the remaining grams of solid NaHCO3 and predicting total pressure under varying initial conditions.
  • Understanding of chemical equilibrium concepts
  • Familiarity with the ideal gas law (PV=nRT)
  • Knowledge of molar mass calculations
  • Ability to write and interpret equilibrium expressions (Kp)
  • Learn how to derive equilibrium constants from partial pressures
  • Study the effects of temperature on gas equilibrium
  • Explore the implications of Le Chatelier's principle in equilibrium reactions
  • Investigate the calculation of molar masses for various compounds
Chemistry students, chemical engineers, and professionals involved in thermodynamics and reaction kinetics will benefit from this discussion.
gtfish
Here's the question (ANY tips or help would be great):
Given equation- 2NaHCO3(s)<-->Na2CO3(s)+H2O(g)+CO2(g)
a. A sample of 100 grams of solid NaHCO3 was placed in an 5 L container and heated to 160 degrees C. Some of the original solid remained and the total pressure in the container was 7.76 atmospheres when equilibrium was reached. Calculate the number of moles of H2O present at equilibrium. (NaHCO3 molar mass= 84 g, PV=nRT, R=.08206 L atm/mol K)
b. How many grams of the original solid remain in the container under the conditions described in "a"?
c.Write the equilibrium expression for the equilibrium constant Kp and calculate its value for the reaction under the conditions in "a".
d. If 115 g. of solid NaHCO3 had been placed in the 5 L container and heated to 160 degrees C, what would have the total pressure been at equilibrium?
Chemistry news on Phys.org
The Total Pressure will be due to water vapours+CO2
The individual pressure will be 7.76/2 . so u have partial pressure of H2O U have its Volume And Temperature.
So u can calculate the no of mol of Water vapours by the eqn u have mentioned
For part (b)
u have initial no of mol of NaHCO3 as 100/84
final no of mol= initial - 2*(no of mol of H2O) [? Why answer urself]
I believe it is better that u do the rest of the Parts/ Or show what u have tried so far on the problem
:smile:
  • · Replies 0 ·
  • · Replies 24 ·
13K
  • · Replies 109 ·
10K
