Block of ice sliding down inclined plane - final speed
The problem involves a block of ice sliding down an inclined plane, specifically focusing on calculating its final speed after descending a certain distance. The subject area pertains to mechanics, particularly work and kinetic energy concepts.
  • Mixed
  • Participants discuss the application of work-energy principles, with one suggesting an energy approach involving potential and kinetic energy. Others question the relevance of this method based on the current lesson focus on work and kinetic energy.
The discussion is exploring different approaches to the problem, with some participants providing guidance on using energy concepts while others emphasize the current lesson's focus. There is no explicit consensus on the best approach yet.
One participant notes that the lesson has not yet covered potential energy, indicating a constraint in the current understanding of the topic. Additionally, there is a mention of a potential oversight regarding the sine function in the calculations.
Edwardo_Elric
A block of ice with mass 2.00kg slides 0.70m down an inclined plane that slopes downward at an angle of 30degrees below the horizontal. If the block of ice starts from rest, what is its final speed?
W = 1/2(m)(v2)^2 - 1/2(m)(v1)^2
W = 1/2(2.00kg)(v2)^2 - 1/2(2.00kg)(0)^2
Fd = 1/2(2.00kg)(v2)^2
wsin(theta) is the only force horizontaly:
(wsin(theta))(0.70m) = 1/2(2.00kg)(v2)^2
2 * ((2.00kg)(9.80m/s^2))(0.70)) = 2.00kg (v2)^2
v2 = 3.70m/s
Ignore the forces and look at the energy.
Work out the vertical distance from the length and the angle
You can then work out the potential energy lost PE = mgh
This is equal to the kinetic energy at the end KE=1/2 mv^2
but this lesson hasnt reach PE yet... this is still on work & kinetic energy
thanks btw
You forgot the sin(30), in your final line of calculations. It should be:
2 * ((2.00kg)(9.80m/s^2)sin(30))(0.70)) = 2.00kg (v2)^2
  • · Replies 27 ·
11K
  • · Replies 18 ·
