What Dye to Use for Plant Stem Cross Section
  • Thread starter Thread starter Swapnil
The discussion revolves around identifying suitable dyes for staining plant stem cross sections for optical microscopy. Participants explore various chemical options and their effectiveness in highlighting specific plant tissues such as xylem and phloem.
  • One participant inquires about the appropriate dye for viewing a plant stem cross section under an optical microscope.
  • Another participant suggests crystal violet as a standard stain for microscopy.
  • It is noted that phloroglucinol is effective for highlighting xylem cells, while toluidine blue can stain xylem blue-green and phloem pink.
  • A participant questions whether simple food dyes could be effective alternatives and seeks information on where to obtain phloroglucinol or toluidine blue.
  • One response mentions that science education stores in the US may carry microscope kits that include these stains, but expresses uncertainty about the effectiveness of food dyes.
  • Another participant asks about local availability of the mentioned chemicals and inquires about other potential dyes for illuminating plant tissues.
  • It is suggested that tropical fish medicines, which come in blue and green, may serve as plant cell stains, with a participant recalling that one of the colors might act similarly to toluidine blue.
  • A link to an online supplier, Carolina Biological, is provided for purchasing toluidine blue.
Participants express varying opinions on the effectiveness of food dyes compared to standard chemical stains, and there is no consensus on the best alternative dyes available.
Some participants express uncertainty about the specific effects of food dyes and the availability of certain chemicals, indicating a lack of clarity regarding local resources and options.
Swapnil
What Dye to Use??
Do you guys know what kind of chemical/dye should I use if I have a cross section of a plant stem and if I want to see it under a optical microscope?
Biology news on Phys.org
Crystal violet is a fairly standard stain for simple microscopy.
Generally, stains are used to highlight particular plant tissues. Phloroglucinol highlights xylem (woody) cells, for example.
Toluidine blue stains xylem blue-green, phloem becomes pink.
Thanks! But wouldn't a simple food dye do the trick??
If not, where can I get phloroglucinol or toluidine blue?
P.S. I actually just want to locate the xylem and the phloem in the cross section of the stem of my plant.
I don't know where you are, but "science education" stores in the US have little microscope kits that have those stains.
I have no idea what food dyes will do. Try them before you buy stains.
Thanks again! Can I buy these chemicals (crystal violet, phloroglucinol, and toluidine blue) from some local store (if so, then which?) or do I need to order them online (if so, then what are some good online stores?).
Also, I tried searching for the aforementioned chemicals at my local chemical dispensary at my college but they didn't had them.
Are there any other chemicals that you guys know of which could be used to illuminate crucial plant tissues inside the stem?
  • · Replies 28 ·
9K
  • · Replies 19 ·
