Thread Closed
Potential/Kinetic Energies
Share Thread Thread Tools
Sep1-07, 11:28 AM   #1
A 12.0kg microwave oven is pushed 14.0m up the sloping surface of a loading ramp inclined at an angle 37 degrees above the horizontal, by a constant force F with a magnitude of 120N and acting parallel to the ramp. The coefficient of kinetic friction between the oven and the ramp is 0.25.
a.) What is the work done on the oven by the force F?
b.) What is the work on the oven by the friction force?
c.) Compute the increase in potential energy for the oven.
d.) Use your answers to parts (a), (b), and (c) to calculate the increase in the oven's kinetic energy.
e.)Use summation{F} = ma to calculate the acceleration of the oven. Assuming the oven is initially at rest, use the acceleration to calculate the oven's speed after traveling 14.0m. Compute from this the increase in the oven's kinetic energ, and compare this answer to the one you got in part d.
2. Relevant equations
W = F * x
U = mgy
K = 1/2(mv^2)
U1 + K1 + Wother = U2 + K2
3. The attempt at a solution
I think there are some typo errors from the back of the book:
W = F * x
W = 120N * (14.0cos(37)) <<<< (x component)
W = 1341.71 J
(the answer at back of book is 1690J)
Ff = ukn = 0.25(12.0kg)(9.8m/s^2) = 29.4N
Wf = Ff ( x)
Wf = (29.4N * 14.0cos(37))
Wf = 328.72J = 329J
(the answer at back of book is 329J)
U2 = mgy2 = (12.0kg)(9.8m/s^2)(14.0sin(37)) = 990.8J = 991J
(the answer at back of book is 991J)
0 + 0 + (WF - Wf ) = U2 + K2
1341.71 J - 329J - 991J = K2
K2 = 21.71J
(the answer at back of book is 360J)
e.) Use summation{F} = ma to calculate the acceleration of the oven. Assuming the oven is initially at rest, use the acceleration to calculate the oven's speed after traveling 14.0m. Compute from this the increase in the oven's kinetic energ, and compare this answer to the one you got in part d.
F - Ff = ma
(120N - 29.4N ) / 12.0kg = a
a = 7.55m/s^2
vf^2 = v0^2 + 2ax
vf^2 = 2(7.55m/s)(14.0m)
Vf = 14.5396m/s
K = 1/2(mv^2)
K = 1/2(12.0kg)(14.5396m/s)
K = 87.238J <<< not same as d i dunno why
(the answer at back of book is a = 0.699m/s^2: K = 360J)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Sep1-07, 11:44 AM   #2
bel
a) [tex]W= {\int_a}^b F ds [/tex], which is to say you don't only take the x component. (So the book did have a typing error here, but the error is less than one percent.)
b) The normal force here is not the same as the gravitational force.
c) [tex] E_K = E_{total} - (E_P + W) [/tex]
d) Remember that forces are vectors and they point in different directions, so [tex] \sum F [/tex] results in a vector pointing downhill (i.e., direction of acceleration).
Sep2-07, 01:14 AM   #3
a.) W = 14.0m(120N)
W = 1680N
b.) Ff = uk(mgcos(theta))
= 0.25(12.0kg(9.8m/s^2)(cos(37))
= 23.4799N
Wf = Ff * d
Wf = 23.4799N(14.0m)
Wf = 329N
c.) didnt follow your formula but increase in potential energy:
U2 = (12.0kg)(9.8m/s^2)(14sin(37))
U2 = 991J
same as B.O.B
d.) U1 + K1 + Wother = U2 + K2
0 + 0 + (WF - Wf ) = U2 + K2 (U1 and K1 are zero ? because the increase of K2 is required )
1680 J - 329J = 991J + K2
K2 = 360J
yup - same ans at Back
e.) F - Ff = ma
(120N - 23.4799N) / 12.0kg = a
a= 8.043m/s^2
(not the same as back of book)
vf^2 = v0^2 + 2ad
vf^2 = 2( 8.043m/s)(14.0m)
Vf = 15.004m/s
K2 = 1/2(mv^2)
K2 = 1/2(12.0kg( 15.004m/s)^2)
K2 = 1350.72J
not also the same
kindly check this
Sep2-07, 01:27 AM   #4
Recognitions:
Homework Helper Homework Help
a) and b) should be in J... other than that a),b),c) and d) are good.
For part e) you need to consider the component of gravity acting along the ramp... for the acceleration along the ramp, you need the net force along the ramp...
Sep2-07, 01:40 AM   #5
ok
e.) Fnet = ma
F - Ff - wsin(theta) = ma
(120N - 23.4799N - ((9.8*12)(sin(37))/12kg = a
a = 25.75N / 12kg
a = 2.1455m/s^2
vf^2 = 2(2.1455m/s^2)(14.0m)
vf = 7.75m/s
K2 = 1/2(12.0kg)(7.75m/s)^2
K2 = 360.375J
thanks
Sep2-07, 02:01 AM   #6
Recognitions:
Quote by Edwardo_Elric View Post
ok
e.) Fnet = ma
a = 25.75N / 12kg
a = 2.1455m/s^2
vf = 7.75m/s
K2 = 360.375J
thanks
no prob. It looks good... But you said the back of the book says a=0.699m/s^2 ?
Sep2-07, 06:56 AM   #7
yes....
the b.o.b. is 0.699m/s^2
is that a typo?
Sep2-07, 07:05 AM   #8
Recognitions:
yes....
is that a typo?
Yeah, I think so.
Thread Closed
Thread Tools
Similar Threads for: Potential/Kinetic Energies
Thread Forum Replies
Maxwell distribution of kinetic energies Quantum Physics 1
Energy Conservation and Kinetic, Wind Energies Introductory Physics Homework 0
Kinetic Energies Advanced Physics Homework 2
Kinetic Energies vs. Momentum Introductory Physics Homework 7
Do kinetic and elastic potential energies have mass? General Physics 7
