Moving Reference Frames and elastic collision
The discussion revolves around a head-on elastic collision between two bodies of different masses, specifically analyzing the scenario where one mass is initially at rest while the other approaches with a given speed. The problem involves concepts from classical mechanics, particularly focusing on reference frames and the implications of elastic collisions.
  • Participants explore the implications of viewing the collision from different reference frames, particularly the frame where the larger mass is at rest. Questions arise regarding the initial and final velocities of the smaller mass in this frame.
The discussion is ongoing, with participants attempting to clarify the transformation of velocities between frames and the application of known facts about elastic collisions. Some participants express confusion about the hint provided and seek further examples or explanations.
There is a focus on the classical velocity addition formula and Newton's laws as they apply to different inertial frames. Participants are also considering the assumptions inherent in the problem, such as the approximation that the larger mass remains at rest after the collision.
fudawala
Consider a head-on, elastic collision between two bodies whose masses are m and M, with m << M. It is well known that if m has speed v0 and M is initially at rest, m will bounce straight back with its speed unchanged, while M will remain at rest (to an excellent approximation). Use this fact to predict the final velocities if M approaches with speed v0 and m is initially at rest.
u = u' + v (the classical velocity addition formula)
Newton's Second Law: F = ma & F' = m'*a' (The two laws for the two fixed reference frames S and S')
Basically, the way I would solve this problem is think that m and M are both masses. Since u = u' + v and u' = u - v, using Newton's First Law, small m is isolated from all outside forces so then the velocity u is constant relative to the lab. Then the velocity of M is going to be v0.
But what's the final velocity of the small mass?
Hint: View things from a frame in which M is at rest, then you can apply the given fact. Once you solve the collision in that frame, transform your answer back to the original frame.
I don't understand the Hint that you gave me. Can you give an example.
The principle of (galilean) relativity says that we can view things from any inertial frame we want. So pick a frame in which we know the answer. In the original frame of reference, m is at rest while M moves with velocity v0. Instead, view things from a frame in which M is at rest. In that frame, what is the initial velocity of m? The final velocity of m?
I think the initial velocity of m is going to be v0 when M is the fixed reference frame. The final velocity will be unchanged when m is bounced straight back without changing the velocity so I would think that the final velocity is constant.
OK. Let's say that initially m was at rest (in the original frame) and M was moving at speed v0 to the right. Transforming to a moving frame in which M is at rest (just add -v0 to all velocities) gives m a velocity of -v0. In other words: m moves to the left with speed v0.
The final velocity will be zero because m came to a hault and stopped when still M is at rest.
m does not come to a halt after colliding elastically with M: it bounces straight back with the same speed.
Remember, you are told this:
You are expected to use that fact.
The speed is unchanged (in the moving frame), but the velocity is not constant. Using what I said in the last post, what are the initial and final velocities of m in the moving frame?
  • · Replies 22 ·
