A question on the Kepler's law
  • Context: Graduate
  • Thread starter Thread starter Rainbow
    Kepler's law Law
The discussion revolves around Kepler's law of areas, specifically addressing the conditions under which the angular momentum of a planet remains constant while sweeping equal areas in equal times. Participants explore the implications of eccentric orbits and the position of the sun relative to the planet's orbit, considering both theoretical and practical aspects of orbital mechanics.
  • One participant asserts that for the area swept by the line joining a planet and the sun to be constant, the angular momentum must also be constant, which they believe requires a circular orbit and the sun at the center.
  • Others argue that the eccentricity of the orbit does not need to be zero for angular momentum to be constant, suggesting that elliptical orbits can also satisfy Kepler's law.
  • Some participants challenge the necessity of a circular orbit, stating that a planet moving in a straight line at constant velocity would still sweep out equal areas in equal times.
  • There is a discussion about the conservation of angular momentum in isolated systems, with some clarifying that while total angular momentum is conserved, individual components can change.
  • One participant points out that Kepler's laws are approximately true, especially in the context of the solar system where the sun's mass is significantly greater than that of the planets.
  • Another participant questions the relevance of tangential components of gravitational force in relation to the conservation of angular momentum and the application of Kepler's laws.
Participants express differing views on the necessity of specific conditions (like zero eccentricity) for the constancy of angular momentum. There is no consensus on whether these conditions are essential, and the discussion remains unresolved regarding the implications of eccentricity and the position of the sun.
Some arguments depend on the definitions of angular momentum and the reference frame used for analysis. The discussion highlights the complexity of applying Kepler's laws in multi-body systems and the influence of gravitational interactions.
Rainbow
According to Kepler's law of areas, the area swept by the line joining a planet(say earth) and the sun is constant with time.
i.e., dA/dt=constant
Also, while deriving we get that,
dA/dt=L/2m where L is the angular momentum of the planet, and m is its mass.
Now, in order for dA/dt to be constant, L should be constant.
I think this is possible only when the following two conditions are fulfilled:
i) the eccentricity e of the orbit is zero, and
ii) the sun is exactly at the centre of the orbit.
Now let us consider a case where these two conditions are not fulfilled-
The Earth revolves around the sun in an elliptical orbit (e is not equal to zero), and the sun is not exactly at the centre of the orbit. Now, at most of the points on the orbit(almost all) the gravitational force of the sun on the Earth has a tangential component. This means that there is a net non-zero torque on the earth. And this essentially means that the angular momentum of the Earth is not constant, i.e. L is not constant. So,now if we have a look at the eq. above, we find that dA/dt is not constant.
Can somebody please tell what the matter is?
It is not necessary for the eccentricity to be zero.
why do you think that the eccentricity must be zero in order for L to be constant? show us your proofs
Remember that in an isolated system, angular momentum is conserved.
Because, only if the eccentricity of the orbit is zero and if the sun is exactly at the centre, the force of gravity on the Earth will be radial and it will have no tangential component. No tangential component means no net torque, and no torque means that the L remains constant.
You are very correct in saying that the L in an isolated "system" is conserved. But here I'm talking about the L of the Earth (a component of the sun-earth system). And conservation of L in a system doesn't essentially mean that the L of the individual components of the system cannot change.
Not only is "eccentricty 0" not necessary, it is not even necessary that the "orbit" be an ellipse.
It is, in fact, very easy to show that if a "planet" were to move by the sun in a straight line at constant velocity, it would still sweep out "equal areas in equal times". That's because the base of the triangles formed would be the same (constant velocity along the line so the same distance in the same time) while the altitudes of the triangles are simply the shortest distance from the sun to the line.
However, you are only interested in the orbital angular momentum. Your model doesn't take into account anything else. The only angular momentum is due to the orbit of one body about another (massive one, so it doesn't even move). It is conserved.
Rainbow, Kepler's second law is approximately true. It obviously is not true in the multibody problem or in the case of two bodies with comparable mass orbiting around each other. (It is also not true in the sense that Newton's law of gravitational is not exactly true because of relativistic effects; I'll ignore that.)
In the case of two comparably sized bodies, each body moves along a conic section (circle, ellipse, parabola, or hyperbola) around the common center of mass. The equal area law is true in the center of mass frame, regardless of eccentricity.
Now, what about the solar system? Since the Sun is much more massive than any of the planets, the solar system center of mass is very close to the center of the sun. The error induced by ignoring the motion of the Sun is small, and thus Kepler's laws are very close to true.
As you said, that the planet will be "moving in a straight with a constant velocity", which essentially means that no net non-zero force is acting on the planet. This is the reason why it sweeps equal areas in equal times. This is a similar argument which I gave in my second post in this thread, where I justified my point that in order for the L to be constant the eccentricity should be zero, and that the sun should be at the centre of the orbit. In other words, the orbit should be circular and the sun should be at the centre of the circular orbit. Now, if a net non-zero force acts on your straight moving planet, it will not sweep equal areas in equal times, as its speed will now change. Similarly, as I mentioned in my question, if the conditions I have given are not fulfilled, there will be a net non-zero torque on the planet which will change its L and hence the rate at which the area is swept.
D H, I'm sorry but, I'm not clearly getting what you said. Could you kindly elaborate what you said.
No, there is just a tangential component, if the sun is moving significantly due to gravity or if you do not take the sun as the origin of your coordinate system. But as Kepler's second law is about the area covered by the vector sun->earth, this is not interesting here anyway.
[tex]\vec{L}=m \vec{r} \times \vec{v}[/tex]
Do you agree?
Then
[tex]\frac{d \vec{L}}{dt}=m \vec{v} \times \vec{v} + m \vec{r} \times \vec{a}[/tex]
So [tex]\vec{v} \times \vec{v}[/tex] is 0 anyway and [tex]\vec{r} \times \vec{a}[/tex] is 0 too, because the gravitational force always points in the direction of the line sun-planet.
As said before, this is not true, if you consider some other point as being the origin for calculating the area, but these cases are not covered by Kepler's second law anyway.
I'm sorry, but your rationale for thinking that gravity causes a torque in non-circular orbits is simply incorrect. Torques only occur when there is a force (or component of a force) that acts perpendicularly to the radial direction. This is implicit in [tex]\vac{\tau} = \vec{r} \times \vec{F}[/tex]. In a circular orbit, this perpendicular direction is tangent to the orbit, so we can just refer to it as a tangential force. However, in an elliptical orbit, the tangential direction is not perpendicular to the radial direction. This means that a totally radial force can, at some points in the orbit, have a tangential component. However, since the tangential direction is not perpendicular to the radial, this cannot be taken as an indication that there is a net torque, which still requires a force perpendicular to the radial direction.
To be explicit, taking the larger object as the origin of a coordinate system, the force of gravity on the smaller object is:
[tex]\vec{F} = -\frac{GMm}{r^2}\hat{r}[/tex].
The torque on the smaller object will, then, be:
[tex]\vec{\tau} = \vec{r} \times \vec{F} = -\frac{GMm}{r^2}\vec{r} \times \hat{r}[/tex].
But, since [tex]\hat{r}[/tex] is just the unit vector in the direction of [tex]\vec{r}[/tex], it is clear that the two vectors are antiparallel, meaning that [tex]\vec{r} \times \hat{r} = 0[/tex], which means that we must conclude that [tex]\vec{\tau} = 0[/tex].
Notice that the direction of motion does not enter into these considerations, meaning that the shape of the orbit is not relevant. All that matters is the direction of the force as compared to the radial.
Isn't it equivalent to conservation of angular momentum? So for two bodies of comparable mass, you just need to consider the area swept around the centre of mass of the system by either body. (And if that's the case then for more bodies, which can exchange momentum, you'd have to rephrase the law as the sum of rates of area sweep by each body, around the centre of mass, that is constant at different times?)
But when I draw a diagram of the situation I mentioned in my question, I get something like this(view attachment).
It's pulled so as to go faster when it's closer, like a skater that draws in their arms. Hence the equal areas in equal times. What's the problem?
Your diagram is correct. The tangential component of the accn does change the linear speed of the planet, speeding it up as the planet approaches the perhelion. The normal component cannot change the speed, only the direction. (Note that the normal component does not point toward any fixed point, as would happen in a circular orbit.) The net result is that the planet speeds up and comes nearer in such a way as to keep the ang. mom. constant.
The reason that you thought that there must be a torque was beacuse you were considering only the tangential component. The normal component also contributes, beacuse the normal, in this case, does not lie along the st line joining the planet and the sun.
Oh now I get it. In case of the sun-earth system, the gravitaional force is an internal force, which cannot cause any change in the angular momentum of the system. And here, though the speed of the planet changes due to the force, the distance of the planet from the sun also changes by just the right amount to keep the L constant. right?
dA/dt=L/2m is not correct.
should be dA/dt = 0.5L
dA/dt=L/2m is correct. Look at the units. Angular momentum has units of ML2/T, while dA/dt has units of L2/T. You are thinking of the specific angular momentum. Specific here means "divided by mass" (just as it does in specific gravity, specific volume, specific heat, specific impuse, ...).
Basically, in orbit around the sun, product of the radius and the component of velocity perpendicular to the line joining the Earth and the sun (ie, the force line) remains constant. There is a tangential velocity as such which changes. The only places where the angular momentum is equal to the product of the m, radius and tangential velocity are the apogee and the perigee.
What I'm saying is, the angular momentum which is conserved is mrv. The v referred is the component of velocity perpendicular to the line joining the Earth and sun. You can see that there is no force in such a direction.
  • · Replies 0 ·
