The jolt you feel when electricity flows through your body
  • Thread starter Thread starter Tempus Fugit
    Body Electricity
The discussion revolves around the experiences and physiological effects of electrical shocks, particularly from high voltage sources such as AC outlets, welding equipment, and other electrical devices. Participants share personal anecdotes and inquire about the underlying mechanisms of how electricity affects the body, especially the nervous system and brain.
  • Some participants describe the sensation of electrical shocks, noting that the jolt can affect the entire body and particularly the brain.
  • There is mention of the role of nerves as electrochemical systems, where electrical currents can cause nerves to fire and muscles to contract.
  • One participant distinguishes between afferent nerves, which register pain, and other nerves that trigger muscle responses.
  • Several anecdotes are shared about personal experiences with electrical shocks from various sources, including welding and high voltage equipment, highlighting the intensity and physical impact of these shocks.
  • Discussion includes the mechanics of electric shock, emphasizing that it is the current, rather than voltage alone, that can be lethal, with specific references to the thresholds of current that can affect the heart.
  • There are explanations regarding how electric fences are designed to deliver a non-lethal shock while still being effective, contrasting with the dangers of high voltage power systems.
  • Some participants express uncertainty or confusion about the voltage and current involved in different scenarios, leading to clarifications and corrections among the group.
Participants share a range of personal experiences and technical insights, but there is no consensus on the specifics of how electrical shocks affect the body or the precise thresholds of danger. The discussion remains unresolved regarding the nuances of electrical safety and the physiological responses to shocks.
Limitations include varying personal experiences with electrical shocks, differing levels of understanding about electrical principles, and the complexity of physiological responses that are not fully explored in the discussion.
Tempus Fugit
When touching an 220/230V AC outlet (or 110V for that matter, haven't got experience with it, but I guess the perceived effect is the same), you not only get the jolt in the place the electrons flow, but it seems to affect the whole body, and most noticeably, the brain.
I was wondering if there's any good articles (or people here who knows) about the complete sequence of events happening when you get an electrical shock. My interest is if there's some kind of extended (more than in usual tissue) electrical push in the nerves (and if this somehow creates a unique input to the brain).
Biology news on Phys.org
Nerves, which trigger muscles and are the basic structure of the brain, are electrochemical systems. The electrical current causes nerves to 'fire', and muscles to contract.
I was talking about afferent nerves, i.e. not the nerves used to pass on information to muscles, but the nerves used to register pain etc.
oh man, don't talk about it. ever got a shock while doing arc welding?? like 45 volts and 80 Amps. now that's a jolt:eek::eek:
I've come between a spark plug and motor block. It through me few feet. Felt like someone hit me hard with a sledge hammer - all over.
And I shorted a 440 V motor. A bigger sledge hammer. Felt like my nostrils were singed.
And I've accidently come between a welding rod and a workpiece. Kind of like the spark plug.
oh boy! and you are still alive? i thought i was lucky
I worked with a guy who grounded a 1MW radio transmitter. His jackhammer broke into the conduit, and even though it was grounded to the casing - he got blasted. He was in a coma for about a week or so, and he had some nerve damage. I think part of that was medication to reduce swelling in the brain.
He was lucky!
what is sufficient for fatal electric shock.
ank_gl, there's some stuff you need to learn about voltage, current, and what's dangerous.
strictly speaking, it's current that's the mechanism that kills you and what organs that current passes through. all you need is about 1/4 amp at the right place (like through your chest), and your heart is stopped.
but you still get to apply ohms law and you need a sufficient voltage to force a sufficient amount of current through your body which has varing amount of resistance (depending on how sweaty the points of contact are, among other things).
i didn't think an arc welder had even 45 volts. i thought it was about half that. when i was in high school shop, i laid my hands on both contacts and did not get shocked. if the voltage is not there, it doesn't matter if it has 80 amps to back it up. it's a lot like a car battery. those suckers need to deliver hundreds of amps to start the car. i would easily dare to soak my hands in saline and grab both battery posts and very little of those hundreds of amps will flow through me. probably less than a couple mA. i probably wouldn't even feel it.
on the other end are devices such as electric fence controllers that anyone whose been around livestock (for me it was a dairy farm) is familiar with. now those controllers want to deliver enough current to the cow's nose to communicate it means business to the cow, it needs to do it under conditions that are wet or dry where there is a great variation in the resistance of the ground that the cow is standing on which is the return path of the electric current. on top of that, if the ground is moist (with less resistance), they don't want to kill the cow or, worse yet, the farmer or the farmer's kid or the kid of some guest. so how do they do that?? how can this electric fence, under wet or dry conditions, consistently deliver a few solid milliamps that tells the cow to back off, might put the farmer's guest's kid on his butt, but not kill either? here is a case where there is a lot of voltage (i think several hundred volts), but deliberately limited current. they deliberately put a large resistance (much larger than the variation of resistance in the closed loop connection) in series with the high voltage so that a consistent amount of current is delivered to whatever touches it. (that resistance is in the actual windings of the step-up transformer in the controller, so it's impossible to short circuit that series resistance.) they also pulse the electrical "signal" applied to the fence so that one can let go, in case the grabbed the wire. it's not dangerous to human or beast, but it *is* to small birds. i have seen the carcass of small birds that landed on the fence (no problem here, just like on high wires) and hopped over to the little steel fence post driven into the ground, and then they pecked at the post (across the little white insulator supporting the fence wire). fried that little sparrow's brain and the bird was just stuck there.
now power systems for home and industry have nearly unlimited current. in EE class, we call that an "ideal voltage source", one that will maintain a fixed voltage no matter how much current it dishes out. if the voltage is high enough and you touch that, unlike the electric fence controller, there is nothing except a 20 amp circuit breaker to limit the current. you probably will not draw 20 amps, but the 5 amps you do draw is easily enough to send you to the next plane of existence.
BTW, for U.S. states that are still barbaric enough to impose death by electrocution upon human beings, the voltage they use can vary (with a controller) between 500 and 2500 volts and it's backed up by 8 or 10 amps. the path is from the crown of the head to one calf (or both calves, in the case of, i think Tennessee) of the leg. they start out with the voltage cranked up to max to insure that the brain is just totally not thinking, but after 30 seconds, they back down to the min so that, without grossing everybody out, they can kinda "cook" the victim sufficiently that there is guaranteed fatal organ damage throughout and just ain't no way that the victim can conceivably recover. pretty ghastly science.
knew that pretty well before:redface:. but didnt gave the 45 volt thing much thought:shy::mad:. anyways its clear to me now.:shy:. duh i m stupid. i am feeling embarrassed:shy::shy:
ive grounded grounded a welding rod before, for some reason i remember it being not so bad. I've also shorted a NST but that was only across a finger, not so bad.
I grounded a teenager once.
Now that was a ...
No wait, that wasn't shocking at all.
Some friends and I were fooling around in a railroad yard when one of them climbed upon a tank car. Although I had previously warned them about the wires (5000 volts, I believe), this guy stood up, and a terrible popping sound occurred. My other friend and I (we were all high) thought the guy on the train was dead. Fortunately the electricity had arced to the left side of his neck, missing his brain and his heart. The charge had exited his left foot, causing the most pain. His metal glasses apparently had been propelled from his head by the electricity. He spent at least a week in intensive care. My other buddy and I still give blood.
  • · Replies 17 ·
11K
