What is the Physics behind the Coaxial Cable?
The discussion revolves around the physics of coaxial cables, specifically focusing on the charge distribution between the inner wire and the outer conductor. The original poster seeks to understand why there is no net charge on the outer surface of the outer conductor when the inner wire and outer conductor carry equal but opposite charges.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • The original poster attempts to reason through the implications of charge distribution and electric fields within conductors, referencing Gauss's Law and the behavior of charges in electrostatic equilibrium. Some participants suggest examining the electric field inside and outside the outer conductor to clarify the situation.
Participants are exploring various interpretations of the charge distribution and electric fields involved. Some hints and clarifications have been provided regarding the application of Gauss's Law and the implications of symmetry in the system. There is an ongoing effort to ensure understanding of the underlying concepts without reaching a definitive conclusion.
There appears to be some confusion regarding the assumptions about charge distribution and the resulting electric fields, particularly in relation to the outer conductor. The discussion is framed within the context of a homework assignment, which may impose certain constraints on the exploration of these concepts.
Bryan52803
"A coaxial cable consists of an inner wire and a concentric cylindrical outer conductor. If the conductors carry equal but opposite charges, show that there is no net charge on the outside of the outer conductor.
Gauss's Law
I tried to approach this problem as logically as possible before laying any numbers to paper or manipulating equations, but was not able to even get that far. Our teacher brushed over very quickly the concept of uniform volume charge distribution and conductors in electric fields. I know there can be no electric field within a conductor. Therefore, if we assume the wire carries a negative charge, then that means there is an excess of electrons that will move themselves to the surface of the conductor, correct? ("If a conductor in electrostatic equilibrium carries a net charge, it must reside on the conductor surface"). So we have a negative field resulting in the cavity thus far. However, if we assume the outside cylindrical shell to be positive in charge, then there will be a positive net charge on the surface of the shell, both on the inside by the wire and the outside as well, correct? Now because of uniform charge distribution, the charge on the inside of the shell will in effect cancel its own field out, still leaving a negative field inside the cavity, but how is the net charge on the outside of the shell in any way negated by the wire? It has to have a positive net charge according to Gauss's law? Thanks for any tips, suggestions or hints!
-Confused student
Hint... looking at the outer conductor... what is the field inside that conductor... what is the field outside of that conductor... uses gauss' law and symmetry for this part...
Then finally... when you know the field inside and outside the conductor... do gauss law using a tiny volume that cross the outer boundary of this conductor...
No... you're right about the inside, but not the outside.
Thanks for the speedy reply!
Actually INSIDE the material, there is no field. In the cavity of the outer conductor, there is a negative field resulting from the wire, E = k(-q)/r^2, r being the distance from the wire and -q being the charge on the wire. If the outer conductor has a charge of +q, then the total enclosed charge by a gaussian surface surrounding the entire cable would be 0, meaning there can be no field outside of the cable, and if there's no field outside the cable, there can be no net charge on the outer surface?
If that is the logic, then what is going on in terms of electron arrangement and such to make this occur? I think I get it, but it's still a little hazy and I want to make sure I fully understand the concept.
Actually here's another way to think about it... actually simpler this way... since the inner and outer conductor have equal charges... and since the field inside the outer conductor is 0... that means the net charge inside a gaussian surface within the outer conductor is 0... That means that all the positive charge must be on the inner surface... hence the outer surface must have a net charge of 0, and by symmetry a charge density of 0...
I understand! Thanks for the explanation!
You're welcome. :smile:
  • · Replies 16 ·
